Does anyone have the SX28 in EAGLE Lib — Parallax Forums
Brian CarpenterBrian Carpenter Posts: 728
edited 2006-03-17 03:48 in General Discussion
It's Only A Stupid Question If You Have Not Googled It First!!
    edited 2006-03-15 17:42
    28-dip 0.3" should work.
    ·1+1=10
  • StarManStarMan Posts: 306
    edited 2006-03-15 17:59
    There is a library on Cadsoft's web site called scenix4.lbr (attached here).· I haven't·used·any parts·in a design yet so I can't verify it, but it looks to be all there.· There are some other miscellaneous parts in there as well.
    Chris I.
    Post Edited (StarMan) : 3/15/2006 6:03:26 PM GMT
  • Rob v.d. bergRob v.d. berg Posts: 89
    edited 2006-03-15 18:50
    Here an·other one, also with pads.
    regards,
    Rob.
    edited 2006-03-16 08:11
    You can always use two 14 pin DIPs end-to-end [noparse][[/noparse]both in real hardware and in the graphics].
    When I call up 28 pin DIPs in Eagle, I just get the wider version -- so at some point I have to create my own graphic or add on to the library.
    I still haven't done so.· I tried downloading and inserting Rob's -- didn't take.
    Whoopee!· It took.
    Be sure to create your library's name before you try it.
    Post Edited (Kramer) : 3/17/2006 7:50:04 AM GMT
  • John BondJohn Bond Posts: 369
    edited 2006-03-16 10:41
    I think there is a full set of SX chips on the CADSoft site, 18, 20, 28 48 and 52 in all pachage styles. It's the one I use. There are also other libraries with only the 20 and 28 DIP in them.
    John
  • les_blueles_blue Posts: 15
    Try this.
    28SX dip package only- I've verified it on 3 PCBs without issues.
