What is a µ-controller with OTP memory type?
Hello,
Having a look at the Basic Stamp's FAQ document, I can see that the BS2 model is fitted with a PIC16C57.
In the data sheet from MICROCHIP, it is stated that·this µ-controller·has an "OTP" memory type.
In my understanding, OTP stands for One Time Programmable. But in fact, as far as I can use my differents stamps up to today, I can reprogram them any time I like.
I'm confused.
Roger
Savigny, SWITZERLAND (french speaking part)
I'm confused.
Roger
The PIC16C57 contains the basic interpreter NOT you basic program. Your program is stored in an EEPROM that is also on the BS2.
The interpreter code in the PIC reads your program from the EEPROM and performs whatever action it requires.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Wise men know when they're right. The wisest also·know when they're wrong."
Thank you, Bean.
Roger
Is the PIC16C57 used in the BS2 different from the standard OTP, or does the BS2 just not use it's internal program storage?
JohnnyB
Jon Williams
The PIC does use the "storage space", as you refer to it, of the 16C57...but only to hold the PBASIC interpreter. As you have noted, this is a One Time Programmable part so nothing in the PIC is changing (in the program space). Thi PIC is running a program, Parallax's Intellectual Property, which fetches PBASIC "tokens" from the EEPROM and interprets them. These "tokens" are created from your source code by the .dll which Parallax generously provides for third party use and is part of the IDE and then they are downloaded to the EEPROM as part of the programming process...again by the .dll.
HTH
Next question:
So if I create a program in a prototype project that runs on a BS2, is there anyway to boil this down to the code necessary to burn it right to an off the shelf PIC16C57?
Just having the token code wouldn't do it because that still requires the interpreter?
The end game here would be using the BS2 to prototype a circuit and program code that could then be used in a product that doesn't require a BS2, but just the PIC16C57 with a permanent program installed.
JohnnyB
Do you need to use a PIC?
If your concern it the relatively high cost of a BS2 compared with a 'off the shelf' PIC, you may want to consider the SX chips instead, as they can be programmed in SX/B, a Basic-language that you DO compile onto blank chips.
Simplicity of Basic, speed like a greased ferret...
Don't visit my new website...
The closest you're going to come is to use the PIC Basic Pro Compiler from Micro Engineering Labs. There you can use their compiler to create native PIC object code to later be "burned" in a PIC. Here is their web site, but bring your wallet:
http://www.melabs.com/
Bruce Bates
<!--StartFragment -->
SX sounds like a decent option too.
In the final analysis it would probably turn out that in the volumes I'd be talking (low) a BS with it's onboard circuitry would probably be the best bang for the buck.
I have a lot of learning to do before I can come anywhere close to making any realistic estimates of feasibility, cost, etc.
Thanks guys,
JohnnyB
The primary expense is to keep the doors open and the knowledge flowing.
Many of us just naturally start out thinking that 'reverse engineering' a BasicStamp would be a piece of cake, but begin to find out that there is a lot of experience and history behind it.
While I may be near to doing so than three years ago, I am not sure I would want to. I would probablly have to eat and sleep computers for another few years and then taking it to market would still be far behind the competiton [noparse][[/noparse]Parallax of course]
If you want to do Basic and get into some Assembler, the SX-28 at $3USD each is way ahead of the BasicStamp in cost. But, there is a lot more learning eventually involved.
It is the journey, not only the destination that is rewarding.
