What's wrong
I'm in progress of completing my first·mini robot (for my degree final year project!). I've construct my own circuit, rather than buying an already complete robot kit. I've connect the·BS2 just like the way·in this schematic i made.·The problem is when i connect the·BS2 with my PC using serial cable, they indicated, echo-yes, loopback-no, and no indication of version and no device type·in COM3. Even when i tried to run any program to my BS2, it indicates "no basic stamps found". Is the problem at my serial com circuit or at my BS2 hardware connection? Please help me with this...
Let's try our best together!
Jon Williams
Why are you looking for com 3?
Maybe you use a usb to com interface and than you have to check the right port(check into your material com availaible)
Greatings from Belgium,
Michel
MICHEL
Michel
Please be sure than when you turn on power on to your bot the green led turn on too.
Michel
On a DB-9M· ·RD = 2 and TD = 3 and GND = 5
On a DB-25M· RD = 3 and TD = 2 and GND = 7
· Measure for your +5V at the STAMP pins 21 & 23, in case you are missing a Ground (don't measure from the 7805 GND.)
· An "ON" LED? -- What a Concept!!
Post Edited (PJ Allen) : 3/14/2006 9:32:40 PM GMT
Michel
Since you do not get loopback, check your serial cable (schematic shows DB25).
If you use DB9 on your pc, com port pin assignments are different.
regards peter
Since your BS is not programmed, these are inputs, so your leds
should be off.
You measured 5V at pin21 so your BS is powered.
regards peter
2) Are you using a DB-25?· DB-25 is a parallel port.· The wiring shows serial port wiring (RX,TX,etc)· You may be wanting to use a serial port.
csavage@parallax.com
DB-25 is just a connector. Originally, RS-232 ports on PC's were DB-25 as well as the Parallel port. Later PC's used the DB-9 for the Serial Ports.
PJ's post explains it well.
Post Edited (pwssr) : 3/15/2006 1:29:16 PM GMT
"OEM NMEA GPS Module" Now available on ebay for only $17.49
http://www.allsurplus.net/Axiom/
· You might want to check in Device Manager and see if you have a serial PORT available (COM & LPT).
· Does this computer have USB?· You may have to obtain a USB-to-serial converter.
PS -- Can we ditch that cry-baby emoticon???
Post Edited (PJ Allen) : 3/15/2006 7:21:51 PM GMT
(Old XT and AT pc's used to have a subd25 male serial port connector)
If you don't have a 9pins subd male connector on your laptop, you don't have builtin
serial ports. If you have a usb port, get hold of a usb2serial cable.
Your 1st post mentions COM3, what kind of connector belongs to COM3?
regards peter
(And is usually a RJ-11 or RJ-45 connector)
Get a decent USB-Serial adapter is my advice.
The FTDI-based one that PArallax sells is GOOD.
Many others doesn't connect all the signals, so they won't be able to reset the Stamp to initiate communications(The same devices usually won't work with PalmPilots or Psion/Symbian PDAs, either.), so if you buy from somewhere else, make certain you can return it for a full refund if it doesn't work...
Don't visit my new website...
October 1963: RS-232 becomes RS-232-A and includes 25-pin connector (max length of 50 feet for cable)
The 9-pin serial connectors appeared commercially first on AT PCs in the early 1980s.
To switch between 25 pin and 9 pin:
*You must switch TD and RD pins on the DTE side. This puts the DTE TD pin data into the DCE RD pin and the DCE TD pin data into the DTE RD~
Ryan
Ryan Clarke
RClarke@Parallax.com
