Servo Speed
Hi folks
Quick question about the speed of servos.· Is there any way to increase the rotational speed of an unmodified (not continuous rotation)·servo?· I can sacrifice torque for speed.· There might be a possible link to the EFX group as my application is animatronic in nature but thought it could post in robotics as well.
Bob
Post Edited By Moderator (Jon Williams (Parallax)) : 3/14/2006 6:49:42 PM GMT
Bob
There are only two ways I know of to increase the rotational speed of an R/C servo. One is a bit dangerous, and the other is not.
You can increase the applied voltage, but you stand the risk of burning out the servo, or causing short life. The other method is to use external gearing. Here is a web site which has external gears for servos:
http://www.servocity.com/html/gears___sprockets.html
Bruce Bates
<!--StartFragment -->
Bigger WHEELS in an animatronics project? Humm.
Bruce
Physics is wonderful stuff [noparse]:)[/noparse]
csavage@parallax.com
And yes, there's no such thing as a free lunch, so the left instance shaft will move with more FORCE than the right instance shaft. In many cases, that's not a problem.
So, a servo has a certain torque it can put out. You can use that torque close to the servo shaft, and get more force over a shorter displacement, or use that torque further away, and get a larger displacement (and faster movement) with less force. In either case, the torque remains constant.
·· That is correct.· I remember once having this discussion with some friends when we were younger.· They wanted to make their dirt-bike go faster by putting a larger sprocket on the back.· I told them a larger sprocket on the wheel side would make it go slower, but if they could increase the drive sprocket it would go faster.· Never could get my point across...
And while we finished the semester, I'm still not entirely happy with the course-work. But it's on my to-do list.
Just as an exercise in pickiness (I have not yet had my morning tea...and, besides, learned discussion/debate just tends to wander along "interesting" paths, or at least provides additional information), I was responding to Robert25's initial inquiry about increasing, specifically, the servo's rotational speed. Bruce's suggestion of a higher voltage would indeed effect this (effect used correctly <g>). Your and Bruce's suggestion of gearing would produce speedier output (with the necessary loss of torque), but not increase the servo's speed.
</pickiness>
Interesting discussusion.· The larger servo horn might work in this instance.· The application, as I had indicated in the original post, was in animatronics.· Something that would work a movable jaw or eye cover etc.· Both of these don't require a lot of torque.· I have been surfing for various servos and looking at the speed specs.· Since I am relatively new to this hobby I might need some help in interpretation.· They use a·· sec/60 degree spec.· I assue it is the time to rotate 60 degrees.·· That being said I found the standard servos usually fall in the 0.2 range.··· I have also found servos that fall in the 0.07 to 0.1 range; presumably quicker.
For the application, think of how fast your eye blinks.· Of course close or an approximation is ok.·
·· In this application I think "speed" is a subjective term as it applies to what is being done.· While technically the shaft is not rotating any faster the fact that I can make a shaft move faster by simply increasing the size of the servo horn proves my point.·
·1+1=10
The speed of an R/C servo is DIRECTLY proportional to the applied voltage, and depends also on the manufacturer. I find no surprise at all in those facts. If were we talking about PM DC motors only, and their respective characteristics, there probably wouldn't even be a discussion. Motors are wound by different manufacturers differently, as well as having a different number of poles·and DC motors used within R/C servos may also be geared differently.
I spent about 2 weeks making inquires of various manufacturers, about 4 years ago, to make this very determination. Sadly, there is no standard measure. Some manufacturers offer two sets of data, one at 4.8 VDC, and the other at 6.0 VDC. We all know there are plenty of 7.2 VDC battery packs out there, so this is obviously a "nominal" voltage. Rarely did I see any manufacturer state a MAXIMUM PERMITTED voltage, although, when asked directly, they did have some particular, unpublished voltage in mind.
The following table is quite incomplete, and DOES NOT represent similar servos, necessarily. All it is intended to show is the variety of data supplied by various manufacturers. Smaller, more common or "standard" servos were chosen for inclusion. Some of the servo model numbers are indicated, some are not. Some manufacturers also did not supply the number of degrees of travel, or didn't indicate the applied voltage. Those that did, have the data included.
/code
·Mfgr········· Model·· Voltage 1······ Speed····· Voltage 2······ Speed
··············· Number···· D.C.····· Sec/Degrees···· D.C.····· Sec/Degrees
Hitec········ HS-422····· 4.8··········· .21/60········6.0········· .16/60
Futaba····· S-148······· 4.8············ .23/60········6.0·········· .19/60
FMADirect················· 4.8············ .23/??········6.0·········· .20/??
Airtronics···················································· 6.0 ········· .14/??
Associated················ ?.?············ .19/60
Hobbico···················· 4.8············.19/60······· 6.0·········· .15/60
Multiplex··················· 4.8············.18/??······ · 6.0········· .15/??
Tower······················ ?.?·············.22/60
Hobbies
Traxxas···················· ?.?············ .22/60
code/
As you can see, there is a good bit·of varience within some fairly tight ranges. Whether it matters, is·wholly dependant on the application.
Bruce Bates
