BS2 I/O electrical specs not clear to me
Reading the electrical specs for a BS2, I can read:
Source/Sink Current per I/O: 20 mA / 25 mA
Source/Sink Current per unit: 40 mA / 50 mA per 8 I/O
I don't understand:
1) the difference between Source and Sink
2) why it is stated per unit...per 8 I/O
Can someone explain?
I don't understand:
There are two pin groups: P0-P7, and P8-P15 -- you'll want to add up all the current requirements for each group and make sure they do not exceed the limit specified.· All of this has to do with the architecture of the underlying silicon.
Jon Williams
One more question please.
If I understand you well, should I connect (i.e.) a 25mA LED's cathode to the BS2 and the anode to Vdd, it would not harm the BS2. Reverse, connecting this same LED's cathode to Vss and the cathode to the BS2, I might have an issue? Is this correct?
Roger
Savigny, SWITZERLAND (french speaking part)
Jon Williams
csavage@parallax.com
