Searching equivalence for MN13811 Voltage Regulator for BS2 OEM
Trying to build my own "OEM" board, I can't find the MN13811 Voltage Regulator component; not even an equivalence.
Does somebody have a idea what component currently replaces the MN13811?
I'm just surprised that you say "The BS2 OEM uses the LM2940...". Actually, the schematic I have downloaded from PARALLAX.COM mentions the MN13811 (see attachement).
May I kindly ask to compare the attached schematic with the one you have and let me know if they are (almost) same?
Thank you anyway, I'll try out the LM2940
Roger
Savigny, SWITZERLAND (french speaking part)
Jon Williams
In the schematic you posted, the big yellow box in the upper right labeled VR1 with LM2940-5.0 written just above it, is the voltage regulator. The MN13811 is there to force a re-set of the Stamp if the supply voltage drops below a certain level (which is preset inside the MN13811). This chip is made by Panasonic, and is available here in the U.S. from Digi-Key. This type of device is known as power supervisor or reset supervisor (or sometimes supervisory chips). There are similar devices available from other manufacturers and suppliers. I have to admit, I'm not sure why this re-set function is necessary, but I suppose data corruption is a likely reason.
The only reason I know this is because last year I was planning to build my own BS2 as you are. I have yet to complete that project, but I remember I asked here what the MN13811 was for when I was doing my research. I think in many cases you can do without this chip, however, as Jon has suggested, I chose to duplicate the Parallax circuit, though the part I selected was from ST Micro and not Panasonic.
I hope this info was of help [noparse]:)[/noparse]
- Rick
Yes Jon, I'm not wanting to re-invent the wheel. I'm actually using PARALLAX's schematic. The only issue I have is to find this MN13811. I really appreciate how much info I can get from PARALLAX.
Thank to you, Rick, I know now where I can find this part.
Great
Roger
