Standard Servo Rotation
How do you know how far a standard servo rotates? Do they all rotate 180 degrees? Here is one that I have been looking at and don't know the amount of rotation. I am assuming it is 60 degrees, because that is what the speed uses, but I hope I'm wrong. www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXDEL5&P=0
·1+1=10
Does the same code work for 180 degree servo used only for 90 degrees of arc?
Or are the extremes different code?
I suspect you have to massage your code to fit whatever you have installed.
Matched sets are best within one project. At least matched pairs for wheels.
Think of it this way:
The mechanical stop in servos (standard) are what prevent the rotation from physically going 360- the pulse widths needed to get to the max positions will vary as the pots/resistors/misc. parts in the servo vary (generally less expensive parts are used)-
Ryan
Ryan Clarke
RClarke@Parallax.com
