recommend a board — Parallax Forums
recommend a board
magimagi Posts: 35
edited 2006-03-12 21:01 in General Discussion
Hi.
I have now got control of my Parallax Servo Controller and it works perfect.
Now I need a board to turn things on and off.
I have a Velleman k8056 but there seem to be a delay before it react on a signal and its relays is rather big just for turning 3.15 v on and off.
So can anyone recommend a board that I can control with RS232 only(or with a RS232-IF232 like with the PSC)
so I can turn things on and off with no lag/delay(like the PSC).
I would be nice if there were transistors instead of big relays becouse even the relays give a smal lag/delay when they switch.
Regards Magi
Please start United Religions , UR , for gods sake.. [noparse]:)[/noparse]
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2006-03-12 12:52
    Perhaps this one: http://forums.parallax.com/showthread.php?p=572655
    regards peter
    edited 2006-03-12 12:56
    Part of the delay could be in the RS-232.
    It seems you have to first encode, then decode before something actually happens.
    For 3.15 volts, couldn't you use a FET and one I/O pin?
    You could still run it over two wires to another location.
  • magimagi Posts: 35
    edited 2006-03-12 13:03
    Peter Verkaik said...
    regards peter
    I guess it could work.
    Thanks.
    Kramer said...
    There is no delay when I use the PSC so its not the RS232.
    FET could be ok.
    Is the I/O pin on 5v?
    Hello.
    I have just got my Velleman k8056 to work and react on control signals but the delay on switch is way to long.
    I read that DC-16 work in 38400 baud like the PSC and that is good, but what about the delay.
    Is the DC-16 Board as fast as the PSC in reaction time from control code?
