New javalin fited with BOE , computer does not recognize stamp
Hi
I bought a board of education a few months ago then bought a javalin stamp micro. Acording to the manual the javalin is supposed to be compatible with the beo.
Ive checked the conection with my old bs2 stamp micro before putting the javalin in so the physical conection should be okay.
if anyone could help itd be great-tyler
in the right orientation? The no.1 pin is labeled '1'
on the javelin.
Do you use a serial port on the pc or a usb2serial cable?
regards peter
Are there any updates for the javalin IDE?
http://www.parallax.com/javelin/downloads.asp
(if you installed from the cd, download this latest version)
If you start the Jide Program go to Projects->Global Options
Select tab Debugger. This allows you to add com ports.
Add the comport number you use to connect the javelin.
regards peter
