lithium battery operation at 3.3 volts — Parallax Forums
LoopyBytelooseLoopyByteloose Posts: 12,537
edited 2006-08-01 14:30 in General Discussion
I just returned from the local electronics supply and there are a·lot of 3.7 lithium batteries in stock.
I know that they need a special charger to avoid overcharge·and you need to avoid discharging below 2 volts, but they seem very attractive for running 3.3 volt -5.5 volt logic levels on the SXes.
After all, they are small.· They recharge quickly.· They have a lot of power in them.
The problem is that I couldn't find a 3.7volt charger anywhere in the store.· Do I have to import an expensive one, or is there an easy DIY approach?
    edited 2006-03-11 17:03
    Lithium chargers are not the easiest to build. You should definitely find a single cell charger, such as this one: http://www.sparkfun.com/commerce/product_info.php?products_id=425
    but I find it hard to believe you cant find a local source, even if it comes down to hacking a charger for a device that uses a single cell lithium battery (ipod, many cellphones, etc).
    ·1+1=10
  • dkemppaidkemppai Posts: 315
    edited 2006-03-11 17:38
    You can charge them with a current limited voltage limited circuit. I've done that for many battery technologies, when a charger cannot·easily be implemented in circuit.·If you're working with surplus batteries, for some one off projects around the house the charger may not be too critical...
    -Dan
    edited 2006-03-11 18:44
    From what I understand, lithium batteries require both constant current and constant voltage regardless of load, plus there must be a method of shutting it off when capacity is reached. Because of the inherent dangers of incorrectly charging lithium batteries, I strongly recomend against a homebrew charger unless you know what you are doing. Your comment about making one appear pregnant in another thread just further strengthens the recommendation for purchasing a charger.
    ·1+1=10
  • les_blueles_blue Posts: 15
    edited 2006-03-11 19:21
    Try your local hobby shop, everyone is using lipo's in the electric planes.
    If You can't find a source, try
    http://h1071118.hobbyshopnow.com/products/description.asp?prod=EFLC3000
    I know, shameless plug, but I work for these guys part time!
  • John CoutureJohn Couture Posts: 370
    edited 2006-03-12 06:05
    kramer, Maxim makes an ic for it???
    http://pdfserv.maxim-ic.com/en/ds/MAX745.pdf
    John J. Couture
    San Diego Miramar College
    edited 2006-03-12 08:11
    Hobby shop seems like the easiest place to get something. I see that they·have ones that are adjustible for 1, 2, or 3 cells and various levels of capacity. For a hacker like me, that is what I need as I never know what I want to use next.
    Google research did point out that ALL lithium batteries are temperature sensitive. Heating causes permanent damage. And the Heat can either be from the ambient surroundings or from excessive rate of charge. Over 40 degress Celcius really shortens the useful life. So an additonal thermal shut down might be a very good idea if you are not going to be present during the charge cycle.
    This looks like an ideal BasicStamp project -- measure temperature, sense a voltage limit, provide a charge timer, and control a current limiting charge circuit.
    Sadly, the shipping for an IC probably costs as much as buying a whole charger locally.
    Post Edited (Kramer) : 3/12/2006 8:14:18 AM GMT
    edited 2006-03-12 18:52
    Kramer,
    Is there a datasheet available on the Li batteries? They might have a small circuit for charging it. The temp sensor sounds like a good idea. I seem to remember a circuit in a recent magazine with a note that "next month" they will be adding the ability to charge any voltage battery (because it has some kind of feedback loop). I can't seem to find it, but if I run across it again, I'll pass it along.
    John J. Couture
    edited 2006-03-12 19:28
    Article on building a Li charger
    http://www.seattlerobotics.org/encoder/200210/lithiumion.htm
    Articles and circuits on battery chargers
    http://www.discovercircuits.com/B/batt-chrg.htm
    THIS article looks interesting (by National Semiconductor)
    Using USB port to charge your Li battery
    http://www.national.com/appbriefs/files/AppBrief101.pdf
    Hobby Projects site
    http://www.hobbyprojects.com/B/battery_chargers.html
    Pulse Chargers vs. Linear Chargers
    http://www.zetex.com/3.0/appnotes/apps/an40.pdf
    Google Search
    "Lithium Battery Charger Circuit"
    John J. Couture
    edited 2006-03-13 07:40
    Most of the stuff I buy locally has no data sheet.
    And the label is in Chinese. Now you know why I try to rely on engineering principles.
    With Lithium cells, I have noticed voltages rated in multiples of 3.7 volts and multiples of 3.6.
    Since the electrolic physics cannot change, I suspect the 3.6volt devices do have protect circuitry that is causing the voltage drop.
    Yes, the more I think about it, a thermal cutoff is a very good thing and should override all other charging functions. This was very clear in what I read, higher temperatures do irreversible damage to the Lithium battery chemistry.
    I will go through all you posted with great interest to see if they directly address the 'thermal problem'.
    The battery protector circuits are often not clear about thermal shutdown. This concerns me.
    Since the DS1620 (from Parallax) can be programed by a BasicStamp to operate independently as a thermostat, you can just connect it to a relay or other shutdown circuit. I see no one really discussing thermal shut down in their Lithium chargers, so this might even have a substantial market for R/C crowd that buys and fast recharges many Lithium batteries in the field.
    The battery could sit face-to-face with the IC's surface. [noparse][[/noparse]Maybe I am going to make one of you wealthy, but there it is - a good idea with a market.]
    Having bought a 7.4Volt cell for $60USD and having had it overheat after 4 or 5 charges; and then swell up to the point that I feared real bodily harm; I can see where others would want better control for their investments and safety.
    There are alternatives. My Nokia just went haywire. If I feel that it is not economical to repair, I wil use its Lithium batteries for projects. And I will use the defective phone for a charger.
    Post Edited (Kramer) : 3/13/2006 7:54:36 AM GMT
  • ohararpohararp Posts: 24
    edited 2006-07-27 20:57
    Many of the concerns here I tried to address with the design of my LIPO BACKPACK...check them out at the links below!
    If you are interested in incorporating lithium ion batteries to your micro design or have the need to log gps data points to an sd card besure to check out the links below:
    Storefront:
    www.hbtrainer.com
    Blog:
    http://sdgpsdatalogger.blogspot.com/
    edited 2006-07-31 20:11
    Kramer said...
    There are different Li-ion technologies. Each can have different charge methodologies. I have even heard that some of the newer cells can be charged to 90% in 5 minutes. So, different cells could also have different rated working output voltages.
    -Dan
  • Jason-WIJason-WI Posts: 35
    edited 2006-07-31 23:04
    LI poly batterys have been in the RC plane hobby for the last 3 years. The technology has come a long way as for charging of these battery chemistries. Accidents will happen and when they do you could loose your house or car as some unfortunate hobbiests have. Just search for li poly and fire on RC Groups websight and you will see pictures of a burnt out SUV caused by an overcharged li poly battery.
    Use extreme caution when using Lithium batterys.
    Jason
    He who dies with the most toys wins!
    In the past year of so, I have seen that the NiMh AA cells are being sold with substantial increases in MAh, nearly 3000MAh.
    It seems that there really is little reason to fool with Lithium unless you need the absolute minmums in weight or the quick recharge or both.
    It is a very interest phenomina, teh Li battery is much denser in the amounts of enery that the more conventional batteries.
    That energy density is what makes it potentially unstable.
    It seems the solution is to make very thin cells of retangular sizes.
    This physical configuration seems to provide a package that will have a lot of room to swell rather than burst or explode.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
