Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
IR Emiting — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
IR Emiting
jaeg
156
2006-03-10 23:36
edited 2006-03-12 01:14
in
BASIC Stamp
I read somewere that with the bs2 you don't need an IR emiting circuit if you use the freqout comand. Is this true?
Parallax Engineering
14,406
2006-03-11 02:27
edited 2006-03-11 02:27
Sure...You could use FREQOUT...By without an IR Emitter what is it you're trying to do?
csavage@parallax.com
jaeg
156
2006-03-11 02:52
edited 2006-03-11 02:52
I have a 38 khz detector I was wondering if I had to make a ciruit to emit a 38 khz signal or if I could just use the stamp.
14,406
2006-03-11 04:41
edited 2006-03-11 04:41
You could do either.
You could use the BASIC Stamp or you could use a 555 timer IC.
jaeg
156
2006-03-12 01:14
Sign In
Register
to comment.
