Programing the BS2 — Parallax Forums
Programing the BS2
jaegjaeg Posts: 156
edited 2006-03-10 23:20 in BASIC Stamp
I was wondering if the serial port in this schematic has the pins facing up or down?
http://www.parallax.com/dl/docs/prod/schem/bs2revf.pdf
    edited 2006-03-10 18:29
    jaeg,
    This would be looking directly at the male-DB9 plug on the PC, or the solder side(back) of the female-DB9 plug.
    Beau Schwabe
    IC Layout Engineer
  • jaegjaeg Posts: 156
    edited 2006-03-10 18:35
    Thanks, I was wondering if it is safe to plug my programer directly into the serial port instead of having a cord from it to the computer.
    EDIT
    This side?
    Post Edited (jaeg) : 3/10/2006 6:43:10 PM GMT
    edited 2006-03-10 19:33
    If you look very closely at the connector you will see that there are little numbers next to each pin.· You should follow those numbers.· They are consistent when you are dealing with opposite genders.
    csavage@parallax.com
