motorized security camera base
I'm relatively new to the forum and never worked with a Stamp.· I'm thinking about using a Prop-1 to control a motorized camera base.· I want it to pan the camera x degrees, pause for so many seconds, then pan and pause again, doing this continuously in a ~270 degree arc (i.e. it will pan back and forth, with pauses every so often).·
The camera with weatherproof housing weighs a few lbs - is there a robotic piece, like a wheel kit turned horizontal,·that parallax sells that I can use to work with a servo to make the base?· I was thinking of using a servo to drive the rotation, but I don't think a direct mount of a plate on the servo will be able to bear the weight.
I'm new at this type of project, so please excuse the basic question.
csavage@parallax.com
The only issue involved is driving the motor, which would require another circuit, or a prebuilt unit that can be controlled by a stamp. There have been numerous discussions on stepper control, a search of posts would show lots of info. Once you have the hardware, making a program to run it would be fairly simple. I have seen many people wanting to use servos for camera movement, and personally, i find your average servo motor totally useless for the application. Even with prosumer cams that use servos for zoom and focus, they are jumpy, hard to control and have a hard time finding their position. If anyone wanted to use an industrial type servo with encoder capability, then the cost would be a major drawback. The Prop1 isn't what you want for control, unless you need the I / O capabilities it provides for other uses. A BS2 would be more than you would require for something like this. A "compatible" stepper motor could direct drive the camera on a base, the motor just has to be over- rated for the weight or torque.
kelvin
Keep an eye on the rating of your stepper....if you need to step down your gearing (meaning, I think, that your stepper drives a large gear connected to a smaller gear on your camera) you may need an even higher rated stepper.
Steve
Steve
