double-sided header pins?
OK - this is a simple one.
We've all of us seen breakaway pinstrip headers. (See attached).
All that I've seen had legs of unequal length - one just long enough to fit through a PC board. Which means that it's not long enough to stick into a breadboard. And if you stick the other end in the breadboard the other is too short to reliably connect to connect anything to.
But the Parallax "Understanding Signals" kit comes with a little three-pin strip of header pins with equal length legs - so that one end could go into the female connector of the servo wire and the other could go into a breadboard.
My problem? I can't find them.
The catalogs list hundreds or thousands of breakaway pinstrip headers. But they rarely have pictures or dimensions.
Can anyone help me?
Can anyone help me?
Sid Weaver
Do you have a Stamp Tester yet?
If you only need one or two, they are cheaper at Wright Hobbies and I don't believe that you'll have to pay a $5 min. order penalty for a small order.
http://www.wrighthobbies.net/catalog/product_info.php?products_id=48&osCsid=3f7c60ffdf2393d5ccf4dc21a808076d
Rick B
http://www.sullinselectronics.com/cgi-bin/conn.cgi
The codes used in the part # can be found at
http://www.sullinselectronics.com/catalog/38A/Page76-77.pdf
(which shows that the head/tail lengths for this particular part are: 0.318/0.320 inches (close enough to being the "same" length :>)
PAR
http://www.samtec.com/
Kenny
Just to clarify, male means it has pins on both sides and female means it has pins on only 1 side? Thanks.
Which suggests that they would.
As for female - yes. The female pinstrips have a socket on one end and a pin on the other. You have to have a pin to fit to the PC board.
kelvin
1. The plastic spacer is usually not high temperature plastic - so it will melt with heat from the soldering iron. It's best to move the plastic spacer to the other end of pin and use needlenose pliers to hold the pin near where you're soldering. The pliers will act as a heat sink.
2. Since pin spacing is only 0.1 in - I recommend a small piece of heat shrink tubing over each soldered connection.
