Ultrasonic Sensors - Underwater
Has anyone·tried any of the ultrasonic sensors underwater?
I would anticipate that the distance would need to be "adjusted" due to the difference in the speed of sound (or "ultrasound").
I'm working on an ROV, and am looking for something less expensive than hacking a "fish finder".· Idealy, I'd have an "array" of sensors for depth below, depth above (assuming I could get a return off the surface) and objects in front and/or around.
John R.
8 + 8 = 10
John R.
8 + 8 = 10
I guess the way the cheaper fishfinders work is by assuming the temperature of the water you're in....and then they determine the temperatures due to its depth. Temperature differences do play a part in their workings. The more expensive models have a temperature sensor built in for a proper starting point (check the temperature sensors range if you plan to use it in the bahama's and the great white north).
My future father-in-law says there's a heat layer in the lake that fish tend to swim in. The Magic number is something near 48degF....so I'm in teh process of building him a temp sensor line that he can hang in the water and see where this 'heat layer' is.
I think the biggest part of using a standard US sensor in water is the waterproofing.· If the transducer is exposed, it has to push water at ultrasonic speeds to create the sound (which means a big driver)....if its contained, then you have to account for the echo in its chamber and also the attenuation before the sound goes where you want it.
I think this is why waterproofed US sensors cost so much!
Steve
My understanding of these units is that the "logic" is in the unit, and the part you put in the water is only the sensor(s). I may need to do a little more poking around to confirm this. If there are some "brains" in the sensors, then it wouldn't be so bad to use one of these units. For what I'm after, I could even "borrow" one, especially from the one of the ice fishing units (they have a very narrow cone, are very senstive, and don't work that well in "open" water for fishing purposes).
Has anyone worked with any of these sensor units?
John R.
8 + 8 = 10
Ignoring the waterproofing issues, the common ultrasonic sensors will not work underwater without modification since the piezoceramic transducers are designed for transmitting in air and there is a very big acoustical impedence mismatch between air and water
Your "fish finder" transducer may work... Typically there aren't any "brains" embedded in the transducer. It will most certainly be a single beam, 2 wire type. You'll need to play around with the deck unit to determine how to drive it (generally you don't run the deck unit w/o the transducer attached.) Check the specs for the frequency. You'll then need to work up your xmit and recv circuits. Power may be an issue depending on the size of your ROV.
On the software side, if you want to do anything more than bottom/surface detection you'll probably need to apply a time varied gain to account for attenuation from spreading and absorption before doing any sort of target detection. Once you get this far though there is a lot of info out there to go from power received to some sort of useable values. Google "sonar equation".
have fun!
Also tried to think of a way to swing the transducer backwards and forwards across an arc so as a region can be scanned like radar. That would be a scream, but not so easy when the transducer needs to be in water, or a wet box for through hull reception.
Given that water is a much better medium for sound than air, I think you will find the possibilities here quite interesting.
bongo
Installation documents I've seen for echo-sounders and fish-finders for use in boats often state that in fibre-glass hulls, it's sufficient to glue the transmitter to the inside of the hull with epoxy if you're careful not to get any airbubbles in the epoxy.
It won't work in wood or steel hulls, obviously.
I also don't know if it'll work in plastic hulls, but if anyone is willing to donate the equipment, I'll be happy to test it in my cayak.(It's made of PolyEthyleneSomething - PET - plastic)
Don't visit my new website...
John R.
8 + 8 = 10
Do the transducers' ultrasonics pass thru the hull or do they vibrate against it? Curious why steel wouldn't work (although it would certainly prevent it from passing thru).
If fibreglass works, I'd assume plastic would.
Steve
I assume that the "sound" waves were just transmitted through. I am assuming that the chances of finding a hull with the right harmonics to amplify the waves would be between slim and none. I can also vouch for the fact that your fiberglass job better be good, and free of bubbles. It only took one or two times of having to grind and chip the stuff away for you to realize you had better do it right the first time
The only conern I might have with a plastic hull is that some of them are built up with laminated layers of different material. If there are any air gaps, or if the hull starts to de-laminate, I would expect to see some "flakey" behavior of the unit.
John R.
8 + 8 = 10
We just hired a new guy recently who has a sonar background and he had mentioned that the transducers used in larger boats and subs has an excitation voltage upwards of 90KVA but with small current in comparison (100A's is still small compared to 90K but he didn't say what the current was!).
I guess those transducers really need quite the kick to 'sing'!
Steve
