sensing a point on a rope.
mikeweezer
Hello All,
I have a need to know when I have reached a certain point on a wench line. This will send a signal to the Stamp telling the device to shut off. I was thinking of using a magnetic switch that is tripped when a piece of the line, covered with magnetic tape, passes the sensor. Can anyone recommend a specific device?
·1+1=10
mike
I would stay away from anything having to do with magnets, as the winch cable will conduct the magnet force...
If the winch cable will stay reasonably clean, use an optical sensor , or a limit switch thats triggered by a preset "block/ball' thicker than the cable...
Mount the switch on a moveable plate that allows for delay of motor shutdown so you don't stress the cable....
You can also mount an "encoder" disk on the drum and use it to determin play out or in of the cable and gain a greater control of the winch....
Bob N9LVU
thanks
There is alot of intended use factors that figure into this project on which method would be best.
·1+1=10
Thick, or thin?
Any narrow constrictions through which the rope must pass?
Slow or fast travel?
What keeps you from simply observing (by eye) when the (marked) rope passes by and manually turning off the winch?
All these and probably other questions about the apparatus and conditions would possibly affect the kind of solution you'd choose.
PAR
pretty thin, like airline cable
There are no narrow constricutions
fairly slow
I will have two units operating in 2 seperate locations. I need to be sure they turn off at the right moment. Otherwise it will destroy some of the sensing equipment I have.
The application is a Tug-Of-War machine in which 2 groups of individuals are pulling on winches. I need to know when one of the teams has lost.
thanks, mike
-Joe
How will you keep the 2 groups pulling along the same line?
In college we would pull and it wouldn't just be back and forth...we'd sometimes end up 90deg from our starting point but with the center of the line still in the 'safe zone'.
Steve
Also, you could work with an encoder....
Or, you could tie a piece of rope from a 3position switch to the center of the rope.· IF one teams pulls the winning distance, the bit of rope will pull the switch to that corresponding position and give something to indicate by.
A neat thing to do would be to have a roller over the top of the rope that is pushing down with a given force.· Have a force sensor measure the force pushing back from the tightening rope and you could see how much force each team is pulling with.
IF neither team wins within a set time, have an electronic cable cutter fire and send them both on their arses....hee hee!!
Steve
http://mweisert.com/media/ttofwar.mp4
Thanks for you suggestions!
mike
Steve
Rich
There's nothing a good wack with a hammer won't fix
Darn I let the white smoke out again
and I have asked about mixing a optical reader from vex for use with a Bs2 in post.
And I think I read something once one of Myke Predko's books on how to make said items.
Rich
Since the motor is constantly changing direction, how will the counter know if it should count up or down?
thanks
Check this site it sould help some
Rich
How about doing something like the way they put limit switches on some winches or chain motors? Just bolt a drilled solid ball, perhaps 2" diameter polyethylene or nylon with a set screw into the wire rope. Place this a foot ot two closer to the winch than the strain guage after running the rope through a 1" ID opening plate tube or ring activating a simple limit switch (microswitch) via a flexible coupling (to allow for a bit of overtravel without damage).
If you wanted to get crazy with the money you saved using a cheap microswitch later, the ball could be a hollow cylinder containing a battery and circuitry to condition, digitize and transmit the strain guage output via RF modem to the winch control CPU. In fact, you could hide the strain guage in the cylinder too.
This lack of wires and invisible sensor would make it more robust for a public venue and even more mysterious as to how it works.
If you electrically isolate the winch from the frame and ground, you might be able to use the wire rope to carry the RF back to the receiver using very low power. I believe this isolated cable method is used on one of the 4 cables used to suspend Skycam.
Rick B
Steve
