Can't get the LCD 4 row to work with my BS2px!!!
Hello all,
I recently purchased the LCD 4 row x 20 backlit and I am using the BS2px chip!· I have tried to run the sample programs but nothing seems to work!· The LCD is ok I think... I get the test parallax display when I put it in TEST mode but when I put it in 16200 buad I get garbage on the screen when I run a program.· I tested all the sample programs but none of them work!· Also I am using it on the PDB board!
Is it because the programs are for a BS2 and not the BS2px?
Does anyone have a test program I can use that uses the BS2px chip??
Please help!!!
I want to use this in an application but I can't seem to get it to work period!!
Joe
Please help!!!
Joe
I assume you have a serial LCD, not a parallel one.
You probably mean 19200, not 16200 bit/s - as far as I know these LCDs support 1200 and 9600 bit/s only no more, nothing else.
The serial speed codes of the BS2PX differ from the codes of other BS2 models, because they have different time bases - check
the manual to select the right serial speed code.
Regards
Adrian
I have a BS2 chip and the buad rate code works with 32!· I was able to test all the programs but I can't find the code for the BS2px!
Example:· serout 0, 32, [noparse][[/noparse]"hello"]
Does anyone know it?
thanks
Joe
For the BS2px chip you have the 9600 baud setting on the LCD and then you can use the baudmode number 396!
This worked!
I was able to see the programs run on the BS2px chip!
But still a question:
Why can't I have it set to the 19200 baudrate on the LCD and if I can, what is the baudmode number for this setting?
thanks
Joe
The serial LCDs (eg. by Parallax or Scott Edwards) are parallel LDS with an additional serial interface. These
interfaces are usually specified to support only two speeds 1200 and 9600. This is to simplify the serial interface
design and to reduce extra cost.
The generic baud mode formula for the px is (hope I am correct):
baudmode = INT(4000000 / speed) - 20
eg: speed=19200, baudmode=188
Adrian
Jon Williams
csavage@parallax.com
