Serial Pole Display problems
I am having major problems trying to get a pole display to accept text from my stamp.· I tried a DP2000 display with no luck.· I just purchased a DP2100 and still get nothing.· When I connect the stamp to hyperterminal I get all the correct information.· When I connect the Display to the computer I can read everything I type on the display.· The output from the stamp to the display gets nothing at all.· The displays are 9600,N,8,1.· I am using the command SEROUT tx, 84, 5, [noparse][[/noparse]char]· (TX is Pin 15).· I also tried using hanshaking, and I tried tying serial port pins 1,4,6 together and 7,8 together.· I am using the MAX232E built onto the professional Development·board.· Can anyone help me?· Has anyone had any success using any of these displays?
Thanks.
Jim
Thanks.
Jim
Jon Williams
The pole display is from Posiflex.
http://www.posiflex.com.tw/object/Manuals/User/UMPD2X00B4.pdf
Jon Williams
·1+1=10
I was hoping someone out there has used one of these displays and got it going.· Maybe I need to make a different serial circuit using somthing other than a Max232e chip...?
Jim
Jim
If you send data to the pole from your MAX232E circuit to the pole, it does not.
Have you tried sending data to Hyperterminal on your PC from your MAX232E circuit?
Verify that PIN15 is truely outputing the 5VTTL signal, then check the output on the Max233 to verify that it is sending the RS232 signal.
Jon Williams
Jon Williams
Jim
