Professional Development Board USB
I recently purchased a Professional Development Board and I am having trouble getting the USB port to work. The port is recognized when connected but "Identify" does not find the BS2 or BS2P·module. When a program is ran, "No Basic Stamps Found" is displayed. If I·start a serial port program through the serial port and then disconnect it and connect the USB, I have bidirectional communication. I have set the port latency to 1 and changed most of the port settings without success. Any ideas? Thanks.
Jon Williams
If it does act as a Virtual Comport, then verify that you are sending the information to the correct comport.· When I dl'd the VCP Driver, it set my USB device up on COM4 (Found in Hardware Manager).· If your Stamp Compiler is still set on Com1, it will see that there is nothing connected at COM1.· If you change that to your new Virtual Comport, then it should see it...
Or I may be no help to you, and you've already tried that.
Post Edited (Steel) : 3/9/2006 5:55:18 PM GMT
