Parallel Capacitor Circuit
sam_sam_sam
Hi EveryOne
Could any please explan to me why you would have two RUN Capacitor on a
Compressor Circuit the value is CAP1 30 MFD @ 370 Volts CAP2 30 MFD @ 370 Volts
Now they make a 60 MFD @ 470 Vols is it because of the voltage that they are doing this
because 370 + 370 = 740 Now These Units run on 220 Volts now this is only on some units
I would like to THANK any one who could explan this to me
You see this in some A\C units
Sam
Sam
The allowable voltage across capacitors in series is the sum of all the voltage ratings.· For example a 470 volt, a 1000 volt and a 100 volt in series would have a voltage rating of 1570 volts.
Sid Weaver
Do you have a Stamp Tester yet?
The voltage ratings of capacitors in series isn't exactly additive.· If they are of the same rating, then they do "add."· If they are of different ratings, then the chain is only as good as its weakest link (or lowest rated voltage.)
Consider an RC low-pass filter and the capacitance is comprised of two capacitors of the same value (2x 0.1uF for equiv. 0.05uF) and·different ratings (one 50V and one 150V).· If the output amplitude was 200V, the XC of each being equal, there would be 100vac across one of the caps and 100vac across the other (not good.)
Thanks PJ Allen and Newzed for explaining this to me
Sam
