Newbie needs help
I've been glancing over the forum's to try and get a feel for stpper motors only to be even more confused than when I started, namely in the area as to how you can control them with a microcontroller (like the BS2p40). Do you need seperate hardware to control them? How many pins from the micro·does each motor need?
Please help
Please help
http://www.parallax.com/dl/docs/prod/motors/Stepper_Motor_27964.pdf
Jon Williams
You'll need to check your motor current ratings against the output capability of the ULN2803 or L293D. Very large steppers will probably require a specialized driver cicuit.
Jon Williams
