pinball project
can someone write me a code for the bs2p40
NEED TO INTERACT WITH A MAX 7219
5 DIGIT 7 SEGMENTS DISPLAY
NEEDS TO HAVE A 10s impulse switch,100s impulse switch,1000s impulse switch and reset back to zero switch
http://www.parallax.com/dl/docs/books/sw/exp/sw29.pdf
Note that this is from an older version of StampWorks and the MAX7219 has been replaced the the MC14489 in the current version (StampWorks 2.0).· Since you only need five digits, the MC14489 can be used.· This article will help:
http://www.parallax.com/dl/docs/cols/nv/vol6/col/nv127.pdf
Jon Williams
