Controller for rocket,
I want to use a stamp as a timer in a rocket to set off servos and what not.
what stamp should I use?
in the future i may also hook up a pressure sensor and use that as an altimeter, so i also need ADC capabilities
BASIC Stamp 1 Project Board
i'm aware that i will need a separate ADC chip to hook up analog sensors.
all i need it to do is count to 5.4 seconds and set the servo to a certain value, then count for 4-5 seconds and set it to another value... can I do this using just the stamp? will it be able to relay enough power for a servo?
Post Edited (salik) : 3/7/2006 3:13:59 AM GMT
Jon Williams
our goal is to get it up to 800 ft using a timer, measure the terminal velocity of the rocket w/ parachute , measure flight time and eject parachute at an optimum time!
There are three leads on the servo, GND and Vcc which can be connected to the battery you power the BS1 with, and a Signal lead which connects to a pin on your BS1.
Don't visit my new website...
I'm assuming you want things to be light light light!!!! So just be wary of the servo's....I don't know how much force you need to move ailerons when moving at mach 0.5 (or however fast you're going) but too big and they'll slow ya down!
Sounds fun though!
Steve
