Servo price and use
I have been wandering why the continuous rotation servo is less than the standard servo. I looked at the manuals, and they looked the same. My other question was if it would be a better idea to use a continuous rotation servo on a joint that only moves about 90 degrees max since in a continuous rotation servo it doesn't have the possibility of going to far and messing up the gears (I assume) or is there a good reason why you should stick to standard servos in those cases.
You'll probably want to know WHERE your joint (arm) is positioned with some reliability. That's easier (less circuitry and programming) to do with the standard servo. Also, if your joint can only move to 90 degrees, what happens when your continuous-rotation servo attempts to make the joint go beyond that limit? Something's got to give.· (Your cont.-rotation servo can indeed "go too far" when incorporated into a system that has other limitations to it.)
PAR
csavage@parallax.com
That is the main difference in actual use.
