parallel resistors — Parallax Forums
parallel resistors
DunnseptDunnsept Posts: 115
edited 2006-03-07 05:07 in Learn with BlocklyProp
I'm just finishing up WAM and have gone through some of the·other materials,
·and have a general question. I hope this is an appropriate place for it.
Every time I see a transistor used as an amp, or trigger or whatever, the schematic shows 2 resistors in parallel on the base.
like:
··········· ---R1---··································/ C
input ---············
Base of trans--|
··········· ---R2----·································\ E
(oooh, ascii art circuits)
if each of R1 and R2 are say 100k ohms, why put them in parallel instead of just a 50kohm
and call it good?· Do the parallel resistors have some other function in this circuit and if
so, could somebody please be so kind as to clue me in?· ;-)
It's been a long time since I've done anything with circuits and I guess I never truly learned it,
since I have now forgotten it all. (an old teacher of mine said that if we truly learned the material,
we would not forget it)
thanks!
paul...
  • Shawn LoweShawn Lowe Posts: 635
    edited 2006-03-06 14:36
    As far as I know, there is no other purpose other than making the resistance you get with the resistors in parallel.rolleyes.gif
    Shawn Lowe
    Remember - No matter where you go
    There you are.
  • DunnseptDunnsept Posts: 115
    edited 2006-03-06 14:48
    That's what I thought. my boss was an AT in the navy, I was an EM, neither of us could think of any reason for
    having them in parallel. But there must be SOME reason, why else would it be done? except maybe to increase
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2006-03-06 14:57
    Paul -
    I'll give you a (rather specious) reason, but I'm not any more pleased with it than you may be. Simply put, it may just be a matter of economics, as it reduces the total number of resistors that need to be supplied to perform all the various experiments, when they can do "triple duty" (singly, in series or in parallel) <sigh>.
    I, for one, would be happy to contribute to the "More Resistors Fund" by sending along a few thousand resistors, if this proves to be the actual case, but I can't in all honestly believe that it is, however <shrug>. Just my best guess, in any case.
    Bruce Bates
    <!--StartFragment -->
    edited 2006-03-06 15:05
    thanks. I've been searching the web for an answer, and it's difficult to sort through the 100's of 1000's of pages that come up.
    I can only think that there must be some reason for it, biasing or who knows what. otherwise, you would just put a (in the above example)
    50k resistor in place and be done.
    now, if you want to donate parts to my learning effort, I'm all for it smile.gif
    I could really use a new computer at home AND a Pro development board, wouldn't mind moving to SX chips either
    edited 2006-03-06 15:14
    Paul,
    ·· In my over 25 years in electronics I myself have never seen two resistors on the base of a transistor, but I couldn't help wonder if it had to do with current consumption.· Maybe instead of using a 1/2W 50K they used two 1/4W 100K?· Sounds weird but...I guess knowing how much current/voltage we were talking might help decide that.
    csavage@parallax.com
  • Robert KubichekRobert Kubichek Posts: 343
    edited 2006-03-06 15:18
    Dunnsept said...
    I'm just finishing up WAM and have gone through some of the other materials,
    like:
    ---R1--- / C
    input ---
    Base of trans--|
    ---R2---- \ E
    and call it good? Do the parallel resistors have some other function in this circuit and if
    thanks!
    paul...
    It also could be that using 2 resistors in parallel the final resistance is closer to the target resistance, due to the
    accuracy of the resistors 1% 5% 10% ect.
    A 100K resistor is a common value, and is used more than a 50k resistor.
    edited 2006-03-06 15:24
    Bob,
    ·· That is true, but then, depending on the circuit, I am surprised to see such a high value on the base of a transistor in the first place.· I guess·we may never know...Unless I can find a setup like this in some circuit and see what's going on.· Reminds me of the good ol' days of reverse engineering.
    edited 2006-03-06 15:50
    Chris -
    Perhaps you missed part of the point here. This set-up is used in the ACTAUL WAM text EXAMPLES! I checked for myself, and indeed it appears just as presented by Paul!
    Who wrote WAM, he should have a reasonable answer?
    Bruce Bates
  • Martin HebelMartin Hebel Posts: 1,239
    edited 2006-03-06 15:55
    A 50K Ohm resistor does not commonly exist. They come in really odd sizes, 47K, 56K, etc.
    By putting 2 common 100K's in Parallel, we can get a nice round value needed of 50K.
    -Martin
    Martin Hebel
    Perform an Employer's Survey of Electronic Technologies Graduates· - Click here!
    Personal Links with plenty of BASIC Stamp info
    and SelmaWare Solutions - StampPlot - Graphical Data Acquisition and Control
    edited 2006-03-06 16:51
    thanks guys, I guess since no 50k exists, but a 47 does, it would make sense then to have it that way. But with the overlap because
    of the tolerance, is it that critical? with 5% tolerance a 100k could be from 95 to 105, and assuming we're at the extremes would put our
    total resistance at like 49.8, whilst a 47k could be 49.3, altho it could also be 44.65. I dunno, are things _that_ critical?
    sorry if I seem too questioning, just trying to learn this stuff.
    thanks again
    Paul...
    (take my calculations with a HUGE grain of salt, no accuracy implied or suggested)
    edited 2006-03-06 16:53
    I think it was simply a matter of making the math easy for the end user. I'm sure Andy will shime in soon.
    -Martin
    Martin Hebel
  • Beau SchwabeBeau Schwabe Posts: 6,569
    edited 2006-03-06 17:29
    Bob,
    From an IC layout perspective, the technique you describe is used, more so to keep a certain level of consistency throughout any process variations.
    With a unitary value resistor, you can either add more resistors in series or add more in parallel to get your desired resistance value. A typical resistor
    structure looks like an array, with "dummy" resistor structures around the perimeter or edge. When trying to accurately match resistors, "dummy" structures
    are important for a couple reasons. One, is so that ALL of the active resistors "see" the same structure as their neighbor. Another reason is for planarization.
    purposes. The best way I can describe this is to imagine a drop of water on a waxed surface.... around the edges you have a curving effect which can
    significantly alter the desired value of the component, so you place "dummy" devices in this region. ...across the middle and top, you still have a curving
    effect, but it's not as severe as it is along the edges.
    Martin Hebel said...
    The odd size I believe migrates from the manufacturing process... We as humans are analog
    by nature, but when it comes to building something, a grid of some sort seems to make sense.
    So... during the processing , the ohms/square unit is applied in a grid fashion. Unfortunately
    the resultant ohms/square does not come out to be an exact figure as we would expect.
    So the "odd-ball" sizes actually make sense from an ease of manufacturing point of view.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 3/6/2006 8:53:58 PM GMT
    1549 x 695 - 1M
    edited 2006-03-06 17:52
    Dunnsept-
    Is this circuit used in the WAM coursework? If so, what resistor values does the text call for?
    Shawn Lowe
    There you are.
    edited 2006-03-06 19:12
    grabbed the WAM.. v2.2·· page 266 for the introduction of transistors. it has exactly what I was talking about. the 10k pot between Vdd and Vss is connected to 2 100k resistors in parallel. Since this is 'showing' 50k ohm, my initial question still remains. why in parallel?
    I can't imagine that it is so sensitive that it could not be replaced with a single 47k resistor since it is being fed by a pot in the first place.
    Or am I really missing something on what the parallel resistors do?
    Post Edited (Dunnsept) : 3/6/2006 7:16:19 PM GMT
    edited 2006-03-06 20:28
    Bruce Bates said...(trimmed)
    Bruce,
    ·· You are correct...I have skimmed through WAM to get a handle on what is included for guidance to other students, etc. but am well past the content and as such have not read it through to completion.· Andy Lindsay is the author and I have e-mailed him and asked him to join this discussion.
  • RDL2004RDL2004 Posts: 2,554
    edited 2006-03-06 20:38
    Kind of like what Bruce said above is it possible the WaM kit comes with 100k resistors, but no 47k?
    Edit: Well, the WaM component list I found didn't show any 47k resistors, but on the other hand, it didn't list any 100k either.
    ·- Rick
    Post Edited (RDL2004) : 3/6/2006 8:46:09 PM GMT
    edited 2006-03-06 21:18
    came with a whole mess of 100k resistors. But I've seen this is many other schematics online too. Like for a darlington transistor
    amp that I built. It too had the 2x 100k resistors in parallel. So this must be some sort of design issue. One of the manuals I have for electronics from the navy shows the same thing, but does not explain why.
    thanks to everybody for trying to help me out.
  • edited 2006-03-06 21:23
    Dunnsept said...
    why in parallel?
    Or am I really missing something on what the parallel resistors do?<!-- Edit -->
    The person who processes my new part requests had to fill more than just her own chair for a while right as I was putting the finishing touches on the What's a Microcontroller parts kit.· Delaying the product release for the 47 k was also not an option.· Fortunately, we did already have 100 k resistors on the shelf.·
    Little did I know how that choice would come home to roost.· Next time What's a Microcontroller comes up for revision, I'll add a box about parallel resistor calculations along with 100 k || 100 k = 50 k calculations and a side note about a 47 k being close enough.·
    edited 2006-03-06 21:48
    Andy, I wasn't trying to 'slam' the book or anything. I was just wondering if there was another reason for having it that way. If it truly is because you need 50k for the input of the transistor and this is how you get there, that's all I wanted to know. I would then assume that it's because of a design issue of the transistor, because every circuit I have seen uses the same setup, 2x100k in parallel. hence, my statement about the "some sort of design issue"
    Your book is excellent and I learned a great deal very quickly, please do not take offense to my questioning.
    thanks to everyone who posted too
    edited 2006-03-06 23:45
    Andy -
    As far as answers go, that was the least expected, and MOST HONEST answer you could have ever offered. It now makes perfect sense, regardless of US noisy roosters! smile.gif
    Bruce Bates
  • edited 2006-03-07 05:07
    Dunnsept said...
    I wasn't trying to 'slam' the book or anything...please do not take offense to my questioning.
    Of course you weren't, and no offense taken.· Your line of questioning was perfectly reasonable, as was the way you presented it.· Also, the answer was not in the book, so the Stamps in Class forum is the next place we hoped you would use to get your questions answered.
    Aside from being an·additional resource for people like yourself who are working through Stamps in Class texts, this forum is also·an important resource for us (the Parallax Education team).··Questions like yours help us improve future revisions of our books, so thanks for chiming-in.··We needed to know about that missing piece of information.
    ...Your book is excellent and I learned a great deal very quickly...
    On the other hand, I might just have to take that one personally.roll.gifThanks for saying so.· Hopefully, it'll make a good launch pad into whatever you want to try next.
    Best regards,
    Andy
