PINK, BS2, and a relay to remote power up/down .... — Parallax Forums
doggiedocdoggiedoc Posts: 2,255
edited 2006-03-07 12:59 in General Discussion
I was just sitting here thinking of a way to bring a "legacy server" online at the clinic from home. Is it feasible to control a BS2 or other Stamp with a PINK from the web to switch a relay to power up a server?
If so, could it be done fairly securely?
Has anyone tried this? I guess I should order a PINK and experiment.
TIA -
Doc
  • steve_bsteve_b Posts: 1,563
    edited 2006-03-06 03:10
    My understanding (as I've purchased one but haven't the time to play yet) is that you can easily change a variable/register via a webpage based on your PINK.
    You can then have a stamp read that register from the PINK which would then, in turn, have a relay setup connected to it where you could indeed cycle the power to something.
    Steve
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2006-03-06 23:17
    Consider this...an RC-4 board has relays on it.....
    Ryan
    Ryan Clarke
    RClarke@Parallax.com
  • stamptrolstamptrol Posts: 1,731
    Doc,
    The PINK (with a stamp attached, of course) will do exactly what you want. One of the samples that comes with the unit lets you click on a browser page and transfer the on/off to a register which the stamp can then read.
    I your case, its important to make sure the router connected to your ISP stays alive even when the legacy machine is off-line. There's a forum member ( Tim, perhaps?) who has/had a neat demo running where you can see the results of clicking the browser button. Uses live video, too. Search for PINK.
    Tom
