Question for PINK users : AUTH schemes your ISP uses?
Hello. This is an open question to our PINK users. As you know the PINK does not currently support auths for SMTP servers (to send email)- There is a reason for this: SMTP (the protocol) does not facilitate authentication. It was never in the protocol, so work arounds have been developed- most use a variant of the following: When you log into a POP3 mail account you authenticate. The Mail server remembers that you've logged in and the IP you've logged in from. If mail is sent within the next pre-determined amount of time, from the same IP address with the same return email address your mail is allowed to be sent. If you never correctly authenticate via POP3 then it won't let you send mail.
There is an RFC 2554 extension that is less widely supported as well.
The problem is that our customers (you guys) may use any (or neither) of these methods for SMTP auth based on what your ISP uses. (This is why auth was not included in the first version of the PINK firmware in the first place.)
So the question is, what do your ISPs use? Do you know? How would you suggest we implement authentication? There were many requests for this here in the forums, but never any responses on what anyone's ISP actually does for authentication.
Thoughts?
Ryan
Ryan Clarke
RClarke@Parallax.com
Thoughts?
Ryan
Ryan Clarke
My ISP requires me to log in....outside of that, I don't know much else.
I'm sure a call to support would get me some odd responses as they might think I'm trying to spoof their system.
Steve
(Friday night here and nothing to do... I need to get a life...)
The system I have seen most often is that the SMTP server assumes you have the right to send email if you use an IP-address belonging to the same ISP as the SMTP server belongs to.
That, and POP3 authentication, of course.
Don't visit my new website...
-Joe
Ryan
Ryan Clarke
Rick
1. Username;
2. Password; and
3. Use of outgoing server port 587
R/J2
Respectfully,
Jay K. Jeffries
Ryan
Ryan Clarke
I've attached the screen shot of this setup tab.
I'll confess ignorance to what it does, just say that it works, and has worked with multiple ISPs.
John R.
8 + 8 = 10
I am not going to claim to be an expert at reading this stuff, but it sure looks like the conversation was all in SMTP, adn went something like this:
From To Protocol Description
Me SBC TCP Open SMTP
SBC Me TCP OK, why not?
Me SBC TCP Let's go!
SBC Me SMTP Response: 220 smtp106.sbc.mail.re2.yahoo.com ESMTP
Me SBC SMTP Command: AUTH LOGIN
SBC Me SMTP Response: 334 [noparse][[/noparse]giberish 1]
Me SBC SMTP Message Body [noparse][[/noparse]contains giberish 2]
SBC Me SMTP Response: 334 [noparse][[/noparse]giberish 3]
Me SBC SMTP Message Body [noparse][[/noparse]contains giberish 4]
SBC Me TCP smtp > 2337 [noparse][[/noparse]ACK]
SBC Me SMTP Response: 235 ok, go ahead (#2.0.0)
Me SBC SMTP Command: MAIL FROM...........
I am assuming that the two Message Bodies were encrypted username and passwords. On two successive messages giberish 1, 2, 3 and 4 were identical from message to message (but different from each other).
The following links may be useful:
www.sendmail.org/~ca/email/auth.html#authsecwarn1 (AUTH in Sendmail)
tp.isi.edu/in-notes/rfc2554.txt (SMTP Service Extension - RFC 2554)
Based on the second link, I would tend to say that while "pure" SMTP might not offer authentication, This RFC adds the possibility of authentication to SMTP (or maybe more properly ESMTP). It is dated 1999, and from the first link, it has apparently been in sendmail since version 8.10 as early as Sept. 1999. Ryan referrs to this RFC, and seems to think it is "less widely supported".
I am not disputing this, but "around these parts" (Wisconsin) it appears to be what most of the providers are using. It is also supported by all the e-mail clients I am aware of. If you look at my screen shot of the e-mail parameters, you'll see options for the other method Ryan mentions as well (check POP first). I have helped "family and friends" set up clients for several minor and all the major ISPs in the area, and they all have used this (separate login) for SMTP authentication.
John R.
8 + 8 = 10
For those of you who have an IP address based configuration for SMTP, how do your ISPs deal with you "traveling"? This could also become a factor for PINKy when used on/in a portable data logger.
John R.
8 + 8 = 10
-Joe
http://www.microsoft.com/windows/IE/community/columns/mailserver.mspx
Both MSN and Comcast use the method of POP before SMTP. In·most cases if the ISP requires you to authentication to receive mail and all you are trying to do is send mail, it will connect to the POP server first for authentication.
JJ
Post Edited (GearHead) : 3/8/2006 8:11:58 AM GMT
I am not trying to be confrontational, but trying to educate myself. You both indicate that the SMTP AUTH is not commonly used, or that other methods are "usually" used.
Here is Wisconsin, the following use the AUTH part of SMTP (or ESMTP if you perfer): Charter Cable, Road Runner (Time Warner Cable), Yahoo (DSL via SBC, AT&T, formerly Ameritech and others), Prodigy (if they are still around), along with local providers PowerCom, PowerWeb, WebConnect, NConnect and a host of others. I can remember working with one user who was authorized by IP address range, and noone that we had to use the "check POP before send".
This is based on my experiences helping "family and friends" and assisting co-workers get things set up (I'm an IT Manager).
Based on my experiences here, and especially with the "big" providers listed, my statement would be "almost all ISPs are using the "build in" SMTP Authentication (RFC 2554).
Is this just a regional thing? Does the "primary" method change by region? Is this all just "chance" on my end? Are your statements based on your "local" trends? If it is regional, do the "big boys" (e.g. Charter, Time Warner, Yahoo) use different methods in different areas?
Please, PLEASE understand, I am asking to learn, not to challange.
John R.
8 + 8 = 10
