Serial comm between PC and Stamp PDB
![confused.gif](http://forums.parallax.com/images/smilies/confused.gif)
I am having trouble using the serial comm between my PC and the stamp PDB. I can use the USB connection on the PDB to download and program the BS2 on the PDB, but cannot use the serial comm. On the message, there is "no echo and loop back", in addition to the "no basic stamp found". On the device manager in the PC, both com1 and com2 are enable and functioning correctly when using other device, like the palm pilot.
Parallax Tech Support suggested that I should uninstall the palm software. I did that, and it is still the same.
Also use the Portmom to monitor any serial port activity. There is none.
Check on the BIOS, com1 & 2 both anabled.
I am using Windows XP w/ sp2 on my PC and using pbasic editor 2.5 on the PDB.
Any suggestions???
Jon Williams
Jon Williams
