Transmit Stall On Comm 1
Hello All
Reading and working through Gunther Daubach's book "Programming the SX Microcontroller".
As I run the code examples in his book my SX Key stops working from time·to time and displays
the message "Transmit Stall on Comm 1".·
I've tried different cables, checked my connections and checked the FIFO buffers.· Still the
message pops up.· Sometimes after the transmit stall alarm I recieve "SX Key Not Found On Comm 1"
message.
Even at times, running in Debug mode,·the Debug screen just stops with out giving message/error
for no appearent reason.
Any thoughts, ideas, or suggestions?
P.S. Gunther's book is excellent for learning assembly.
Thanks in advance
Gordon
message.
Thanks in advance
Gordon
Think I might have this one licked.· Went back into device manager, checked the FIFO buffer(again).
Even though the settings were set about mid-way, this still seemed to cause an issue with
the communitions to the SX Key. After turning the FIFO setting to the lowest settings, all seems
fine and well.
Maybe this will help someone else down the line.
Gordon
For some reason, many systems prefer to run the SX-Key with little to no FIFO buffering. I have exact reason why this is, but it does seem to help a lot of people.
Thanks, PeterM
I switched the 9v supply out for the 7.5 volt 1 amp supply, and things seemed to be resolved. I didn't do anything with the FIFO settings (yet).
John R.
8 + 8 = 10
