BOE X1 plug available ?
Is there a reasonably priced (not $5 like Digikey) 20 pin IDC ribbon cable plug available to match the X1 connector on the BOE?
Why? Once the students have mastered the art of sticking wires into the proto area, I have pre-wired lab experiments that I would like to plug into the BOE to develop & exercise programming skills.
TIA
Don
TIA
Don
- Rick
Don
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=73251
The price has gone up a bit since I bought mine.
It looks like about 40 cents each for the connectors, another 15 cents each for stain reliefs, and cable at about 50 cents a foot, so more like $1.50 per cable. Plus your time and the cost of the crimper. I guess whether it's worth it or not·depends on how many you need and how much you value your time and trouble.
·- Rick
Post Edited (RDL2004) : 3/2/2006 6:53:39 PM GMT
What I would probably do is use 0.1 inch male headers as sort of a socket to socket adapter. I do this when breadboarding sometimes to turn the breadboard socket holes into pins. Just plug the header into the socket then plug your female connector onto the header. With the male headers, usually one end is too short (meant to be soldered to a pcb) but the other end is longer than it needs to be, so just push the pins through the plastic part (they slide pretty easily) till they are about the same length on each side.
The part number at Jameco for a (non-polarized) 20 pin IDC socket connector that looks like it will work is 138325CB (45 cents, page 138 in catalog 261). the double row 20 pin male header is part number 53479CB (59 cents, page 133 in catalog 261). These were the only double row headers I found in their catalog, they seem a little expensive to me, but they are gold plated.
- Rick
Was hoping for a cheaper solution. Thanks for the try.
-- Don
I'm following that idea and trying the pin-to-pin headers.
-- Don
I'm using the 20 pin male headers, as suggested, from Jameco. They work just fine.
Now I have to machine a little block to set it in so I can squash it in the vise and end up with all pins equally pushed out on both sides.
-- Don
