Basic Stamp - Led - Visual Basic. — Parallax Forums
GotenGoten Posts: 70
edited 2006-03-01 11:49 in General Discussion
i only wanted to ask, if someone has managed to ignite a led connected to the basic stamp, programming·by a·visual basic turn.gif
Best Regards from Chile
Goten
www.chilebot.cl
  • Beau SchwabeBeau Schwabe Posts: 6,575
    edited 2006-02-28 22:43
    Does "igniting" a laser count?
    http://forums.parallax.com/showthread.php?p=549166
    Read further down in the thread-link I provided for a VB program.
    Beau Schwabe
    IC Layout Engineer
  • GotenGoten Posts: 70
    edited 2006-03-01 02:43
    well, i used a bad word, i'm sorry for that.
    i just want to do on vb what i do on Parallax editor.
    (if the led is on the pin 6)
    x var word
    inicio:
    for x = 1 to 100
    high 6
    next
    low 6
    goto inicio
    (*) so simple, but i really don't know visual basic, and maybe with a simple example like this, i could get use to the language.
    Goten
    www.chilebot.cl
    edited 2006-03-01 04:21
    Goten,
    You did not use a bad word, I knew exactly what you meant. ... "lighting an LED" or "light an LED" would be a more commonly used phrase.
    I will try to repost a simplified version of my VB code and BS2 code.
    Beau Schwabe
    IC Layout Engineer
    edited 2006-03-01 05:00
    By the way, using PBASIC and trying to learn VB are two different things.· You can communicate between the two for control of the PBASIC program but trying to fully program from VB to learn VB isn't going to happen.· You can't create a form on a BASIC Stamp and drop objects onto it such as buttons and sliders.· They really are distinctly different.
    csavage@parallax.com
  • StaatsStaats Posts: 22
    Nuts & Volts Column 89 "Data Exchange with VB" may be what you are looking for. You can download the .pdf file.
