Basic Stamp/Electronics 101 Question?
···I had read somewhere but can't remember where that a 1K resistor should be put on any of the 16 I/O lines when using them. The reason they gave for this was that would protect the PIN should a un-expected reverse surge take place. Is this fact fiction or did I mis-unstand what was being said? What pre-cautions should be taken if any to protect the basic stamp?
The goal is to keep the current flow through a pin to less than 25 ma. Ohms law tells us that when 5 volts is across 220 ohms of resistance then ~23ma of current will flow. Since the 220 ohm resistor is in series with the input/output circuit that you have built, there will be more resistance than 220 ohms and even less current through the pin.
On the other hand, the 220k is nearly the minimum.
This removes the 'direct connection' to the outside world by putting in a little light and a light sensor which will likely blow when things go bad in the outside world.
NOTE, however, that lightning will kill the opto AND anything within its vacinity.
Lightning protection is a bit of a black art....you never know if you're protection scheme works, until it doesn't work!! haha
I've included a simple picture of a 4N35 optoisolator I've used in the past.
Steve
