Accurate measurement of rotation
I'm putting together a project that needs to precisely measure (say to within 0.33 degrees) rotation of a tripod head in 2 axes. I've had a poke around this site and the web trying to find an approriate sensor, but haven't turned anything up yet. I'm going to assume that pots may be a bit too shaky for precise use, although I suppose it depends on who makes them.
Any recommendations for something appropriate would be greatly appreciated.
Jon Williams
Be aware that a 128 or 256 count encoder will have to be turned slowly or you will lose counts,
I was only able to get about 100 counts per second with a quadrature encoder and a BS2.
If you need to count faster than that, you'll have to add some hardware to do the counting for you.
I think there's something in the Stampworks manual, but if you can't find it,
here's a site that will get you started with that.
abrobotics.tripod.com/Ebot/hardware.htm
Jon Williams
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Never under estimate the importance of being nice when you don't have to be."
It's more hardware than you might've wanted....we use them on our radars
Here's some info on them:
http://www.evaluationengineering.com/pctest/articles/0399daq.htm
http://www.pentlandsys.com/download/synchro/ch1_2.pdf
http://www.pentlandsys.com/download/synchro/ch3.pdf
http://www.pentlandsys.com/download/synchro/ch4.pdf
Analog devices sells some converter IC's in 12, 14 and 16bit flavours.
http://www.analog.com/en/prod/0,,760_791_AD2S83%2C00.html
These are all a bit pricey...but I'm sure you can find some lower end ones that might work for you.
For instance, you could get the hold of an old synchro setup (we used to use them in our old wind equipment) and you could easily attach a 10-turn pot to the end of one of the rotor shafts and just do an RCtime input to your stamp.
Here's a quick look on ebay for ' synchro resolver '
http://cgi.ebay.com/Evershead-Vignoles-Synchro-Resolver-Type-FC34-0_W0QQitemZ7594260290QQcategoryZ42899QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
That address probably won't work unless you copy/paste.
http://cgi.ebay.com/Bendix-HSI-SYNCHRO-Synchronous-Resolver-Receiver-8Pcs_W0QQitemZ7593733146QQcategoryZ71395QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
wrt ebay...buyer beware!
Steve
csavage@parallax.com
