Input Voltage
Is it possible to use a Propeller with 5V memory?
Would 5V damage the input pin?
Do you think 3.3V would be enough that a 5V memory would read it as high?
Thanks.
I wonder if this wire is hot...
Thanks.
Jon Williams
If so, I think many of those who have old 5V APPMods might order a few together with the Propeller...
Don't visit my new website...
would it come through unchanged?
I am thinking that I could divide the voltage from the 5V memory down to 3.3V at the propeller.
Those kinds of dividers only works when the current stays constant. Any variation(the Propeller draws from microamps, into the milliAmp range... ) will translate into a variation in the voltage.
A decent regulator will keep your Propeller much happier(and intact)...
If you're thinking of level-matching for the IO-pins, I'd rather use a chip like those I just linked to.
Electro, you cannot use voltage dividers for power, always use regulators for that purpose. For signal lines, voltage dividers will work when you have a low impedence source termined in a high impedance sink (fancy talk for one pin on the line is output, being read by a pin which is an input). Now for any 5V->3.3V single direction signal, the voltage divider should be used, for a 3.3V->5V single direction signal you would use no voltage divider, and the 3.3V seen by the 5V device should still interpret it as a high level. Now for bi-directional signals (such as the data bus on a memory chip) you would have the voltage divider step down the voltage in the 5V->3.3V direction, it still works for the reverse direction because you are pegging the node between the resistors to 3.3V, after the small capacitance of the 5V device's input pin is charged, there is no current flowing through the resistor between the 3.3V output pin and the 5V input pin, so the 3.3V seen on the 5V input pin should be interpreted as a high value.
·1+1=10
But it is the right class of chips, though, as trying to use the output of 3.3V logic directly on 5V logic is to ask for trouble.
(Yes, dividers can be used for inputs. )
Maybe this one?·· http://www.maxim-ic.com/quick_view2.cfm/qv_pk/1742
There are many others at varying price ranges. I think this one will do about 400ma with 3.3 input.
Jim
In the end, it seems that it's all about getting the LEDs to blink....
·· No that is a regulator, not a tranlsator...At a quick glance I would say this would be a closer match.
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/3672/ln/
csavage@parallax.com
This looks like it will take care of the problem:
www.mouser.com/?handler=data.listcategory&Ne=500&terms=ram+memory&Ntt=*ram*%2b*memory*&crc=false&Ns=SField&N=51122
...TIGER
·1+1=10
Regarding quesitons of timing and bridging, The Art of Electronics convieniently has a whole section of discussion on it.· It covers nearly all the permutations of voltages and chip generatons. See Chapter 9, sections 9.0 through 9.14.· Excellent stuff!
The question is why have the second 3.3 v·regulator fed already regulated? I suppose for better regulation, less noise. But nonetheless, Tiger's solution is very appealing as you begin to fill up a board with regulators and heatsinks rather than more central components.
I also would like to point ou the the FRAM memory [noparse][[/noparse]which I personally think will be highly useful for the Propeller due to it's fast writing speed and duriblity (see www.ramtron.com) comes in an SPI package at 2.7 to 5.5 volts.
We are entering a phase where the hobbyist will have to be more aware of power regulation. One of the greatest innovations of the BasicStamp was to eliminate·many concerns about the voltage regulation, allow a begineer to just plug in a battery, and go.
Whatever come about needs to have similar fault tolerance and duriblity to become extremely popular.· Maybe modular adds-on will be a solution.· Or proto-type area with both regulated voltages.
Post Edited (Kramer) : 2/28/2006 6:12:48 AM GMT
...Tiiger
