how can use a Holux gps receiver with a stamp?
Hello from Belgium,
I'have a holux gps antenna and receiver.
It's working true usb or serial interface.
It's could be great to use this with a stamp.
Could you inform me if you have some data or information about this.
I check on to the holux web site but i d'ont find any answer.
Thanks by advance and sorry for my bad acknowledgment into english speaping.
Answers are welkome in english, french, dutch, german .
Thanks again for your help and first stay Parallax.
Michel
Michel
What is the Model Number of your Holux GPS?
Bruce Bates
<!--StartFragment -->
Michel
One of those ? http://www.holux.com.tw/product/search.htm?filename=gpsreceiver_mouse_index.htm&target=gpsreceiver1&level=grandson
Interface: USB (BU-303)
Output: NMEA0183 V2.2 protocol, and supports command:
Messages: GGA, GSA, GSV, RMC, GLL, VTG
Datum: WGS84
Hot Start: 8 sec.average
Warm Start: 38 sec.average
Cold Start: 48 sec.average
Altitude Limit: 18,000 m (60,000 feet)Max.
Re-acquisition: 100 ms
Velocity Limit: 515 meters/sec(1000knots)Max
Jerk Limit: 20 m/sec**3
Horizontal Accuracy: 15 m 2d RMS without SA
10 m 2d RMS WAAS enabled
1-5 m DGPS corrected
Vertical Accuracy: 40 m 95%
Velocity Accuracy: 0.1 m/sec 95%
Time Accuracy: 1 us synchronized to GPS time
Dimension:
BU-303:
59 mm x 47 mm x 21 mm (2.32 x 1.85 x 0.83)
Power Consumption: 90 mA (include Antenna)
Storage Temperature: -40°C ~ 85°C
Operation Temperature: -40°C ~ 80°C
Humidity: Up to 95% non - Condensing
I hope than you can help me.
THANKS BY ADVANCE
MICHEL
unfortunatly i d'ont understand chinese.
thanks from belgium.
Michel
csavage@parallax.com
Michel
I confirm its a serial whos use a usb "translator".
Maybe you have a shortcut to see nut and volt propositions.
Michel
http://www.parallax.com/dl/docs/cols/nv/vol4/col/nv103.pdf
And another:
http://www.parallax.com/html_pages/resources/custapps/app_gps_track.asp
