X10 PL513 and Basic Stamp
Has anyone developed a source code and wiring schematic for the X10 PL513
power line Interface? If someone has I would appreciate getting some information.
Thank You
Guido
Thank You
Guido
Jon Williams
I apologize for not completly stating what I need. I was wondering if there is any information for receiving X10 signals and having the Stamp Interpret them. I do realaize I can use the X10 command for transmitting signals. It seems the only thing I can find is an RF X10 circuit which I have used.
Thank You
Guido
Here is one method that you may find interesting, thanks to Al Williams:
http://www.awce.com/firecracker.htm
Bruce Bates
<!--StartFragment -->
The problem with recieving X10 signals with the PL513 is that it produces relatively primitive signals, which I don't believe the BS2 is clever enough to interpret.
Now, X10 does make a serial "Computer Interface", which you should be able to hook up to a BS2 and use "SERIN" to interpret its signals. But i've not seen a wiring example for it.
Thank you for the information. It is to bad there is nothing really out there for this. I will check out what you are talking about at X10.
Thank You Again
Guido
