SX power supply
What would be the best way to power an SX chip via a bridge rectifier? In addition to the SX chip, I will also power a 74LS04 inverter. The chips will drive a mosfet H bridge. If you want a schematic of what i'm doing say so.
Thanks.
Thanks.
·· A bridge Rectifier is only one of several parts of a power supply.· Usually the rectifier is preceeded by a step-down transformer (power transformer).· It is followed by filtering capacitors and usually a voltgage regulator.· At this point you can power your SX and TTL logic, but the H-Bridge will most likely require it's own supply.
csavage@parallax.com
Well well, I'm seeing things, three of them.
-Stanley Blystone
