Blocking AC current
Hi!
Phew, back from a tedious half-semester and a little time to work on my Stamp-stuff. I have a voltage regulator (5V switching). Since I have not had time to do stuff I still have the old problem that I brought up a few months ago here. I get 5V DC out, but I also seem to get ~10V AC. Since I cannot seem to eliminate this weird voltage, I was wondering if there is any simple circuit that will allow me to block this current while still passing the direct current to the Stamp (the DC and AC voltage appear to be on the same line).
Rafael
Rafael
I don't think that a bridge/fullwave rectifier will work, you would still see the rectified 10vDC.....
How about a blocking capacitor on the + side ???
It sounds like a switcher from an old computer or desktop that used the 10v ac for timing...
Bob N9LVU
Jon Williams
Rafael
· Have you tested this with a load -- 100ohms (that'd be 50mA and should likely meet any minimum load requirement.)
Or should I connect a light or something?
Rafael
· ** Switching supplies don't like "no load" conditions. **
Post Edit -- I have added a drawing, should there·be any uncertainty as to my meaning.
Post Edited (PJ Allen) : 2/25/2006 10:30:43 PM GMT
