GPS remote readings
I have an idea that seems feasible,but maybe you guys know better.
Would it be practical to feed GPS data into a legal,short range transmitter?The receiver end would feed the data into a PC through a USB connection.I've seen handheld [noparse][[/noparse]GMRS?] radios that have a 2 mile range and don't cost much.But..before attaching wires to the stuff,I could use some ideas about interfacing.
I would like to install this on my track drive crawler,which has a several mile range[noparse][[/noparse]less the R/C limitations].
Thanks,Jim Richey
Thanks, Parallax!
Thanks,Jim Richey
Thanks, Parallax!
No problem doing what you want to do. The data string output by the GPS is very "serial friendly" so you can feed it into a set of RF dataradios. I've used MAXSTREAMS ( documented legal in Canada and US ) and Surelinks ( built to legal standard ) with good success.
Maxstreams come in several varieties and I've tested some Stamp projects at 15 km. The Surelinks ( from Parallax) are easy to work with and I got 1 km without too much trouble.
Regards
Tom
That's very encouraging news for me to hear.I'll check out both sources and hopefully learn some new stuff.
Jim
Thanks, Parallax!
