Overclocking SX52
I just ordered a couple of SX52 protoboards and was thinking of trying to get them to talk to the new Propeller chips (when they come out).
It would be nice to have them both run off the same clock.
Do you think I can get away with clocking the SX52 at 80MHz?
Is there a problem with having multiple MCU's run off the same clock?
I wonder if this wire is hot...
You wouldn't be able to clock both off of the clock, because the propeller has an internal PLL which takes a 5MHz crystal and speeds it up 16x.
You could theoretically take an active oscillator, feed it into both the Propeller XIN pin·and the SX OSC1 pin, then set the Propeller PLL to 1x.
·1+1=10
Post Edited (Paul Baker) : 2/24/2006 6:15:56 PM GMT
http://www.parallax.com/detail.asp?product_id=252-00005
Jon Williams
75 MHz would be fine, but the real issue is synchronization.
This all came as a result of trying to figure out the fastest way to get data in and out of the Propeller.
A 4M SRAM has an 8 bit parallel interface and requires 19 more pins for addressing, plus a few more pins to set the read/write state and clock. Since the Propeller only has 32 I/O pins I was thinking that I could use the SX52 to provide the address and other information while hooking up the 8 data lines to the propeller.
That would let me move data in and out quickly and still have 24 configurable pins.
I suppose I could try to come up with some kind of asynchronous handshaking protocol, but life would be golden and wonderful if I could synchronize both MPUs.
