LCD Problem. Drawing dots on a SGX-120L
Hope I am not wearing out my welcome.· Have some free time this week, so working on a few projects.
I am continuing to experiment with my Tiny Touch Pad.· Now I want to draw on it and have the dots show on my SGX-120L.
My code looks right to me, and the SGX-120L part should work. (hehe)· Could someone look at it for me.· I really appreciate it.
SGX-120L.· I have read some other posts, and suspect I am not sending the correct information in the ESC P line?
Thanks, I really appreciate guidance on this. (note to Jon:· Notice I am finally using your template [noparse]:)[/noparse])
Post Edited (neoteric) : 2/23/2006 9:13:15 PM GMT
' {$STAMP BS2p} ' {$PBASIC 2.5} ' -----[noparse][[/noparse] I/O Definitions ]------------------------------------------------- RX PIN 0 ' input device = Tiny Touch Pad LCD PIN 4 'LCD ' -----[noparse][[/noparse] Constants ]------------------------------------------------------- #SELECT $STAMP #CASE BS2, BS2E, BS2PE T1200 CON 813 T2400 CON 396 T4800 CON 188 T9600 CON 84 T19K2 CON 32 TMidi CON 12 T38K4 CON 6 #CASE BS2SX, BS2P T1200 CON 2063 T2400 CON 1021 T4800 CON 500 T9600 CON 240 T19K2 CON 110 TMidi CON 60 T38K4 CON 45 #CASE BS2PX T1200 CON 3313 T2400 CON 1646 T4800 CON 813 T9600 CON 396 T19K2 CON 188 TMidi CON 108 T38K4 CON 84 #ENDSELECT SevenBit CON $2000 Inverted CON $4000 Open CON $8000 Baud CON T9600 clrLCD CON 12 ' Clear entire LCD screen. posCmd CON 16 ' Position cursor. ESC CON 27 ' Escape code for graphics instructions. ibaud CON T9600+Inverted ' 9600bps/inv. baud for LCD LCDLghtOn CON 14 ' -----[noparse][[/noparse] Variables ]------------------------------------------------------- whatsit VAR Byte(5) x VAR Word y VAR Word newx VAR Word newy VAR Word divx VAR Word divy VAR Word loopit VAR Word finx VAR Byte finy VAR Byte '-----------[noparse][[/noparse]MAIN}--------------------------- Main: PAUSE 10000 'let lcd power up SEROUT lcd,ibaud,[noparse][[/noparse]clrLCD] ' Clear screen. DEBUG "Begin" ' to pc debug screen SEROUT lcd,iBaud,[noparse][[/noparse]LCDlghtOn] 'works SEROUT lcd,ibaud,[noparse][[/noparse]"hello"] 'works, but sometime inverted DO SERIN RX, baud,[noparse][[/noparse]STR whatsit\5] '' x = whatsit(2)<< 7 + whatsit(1)-115 '' Reads X,Y from input device y = whatsit(4)<< 7 + whatsit(3)-90 '' IF whatsit(0) = 137 THEN '' 'DEBUG "x = ",DEC x,",y=",DEC y,CR '' newx=119*x/1650 '' Converts to <120 newy=31*y/3850 '' Converts to <32 finx=newx '' Stores as Byte finy=newy '' Stores as Byte DEBUG DEC x," - ", DEC y," ",DEC finx," ", DEC finy,CR 'View results on PC Screen Works' [b]SEROUT LCD,ibaud,[noparse][[/noparse]ESC,"P",finx,finy] ''' draw point DRAWS GARBAGE?????[/b] ENDIF LOOP END
csavage@parallax.com
Anyway, I figured it out from the docs.· I misunderstood it in thier sample code.
Thier doc on thier site·says "Numbers can be expressed either as ASCII text (e.g. "123") followed by a throwaway character, or as single-byte shortcuts. Shortcuts are the one-byte sum of the number to be sent, plus 64. Numbers up to 191 can be sent this way to increase serial throughput. See the user manual for examples."· To plot a point at x,y·- ESC P X,Y.·
Apparently I need to add 64.· So the code would read:
Thanks.· Sometimes these docs are a little difficult for a beginner.· Like the phrase "followed by a throwaway character."· What the heck is a throwaway character?· Sometimes a newbie has to read a line from the doc, do a google search.· Read the next line, do a google search.· Its·very easy to miss something, or get confused.
