Registry Structure?
32 bit O/S and 32 I/O pins, hmm....
Is it possible to push data from a register at one bit per pin?
Like if you set an SX register to output and then moved a byte into that register.
I'm trying to figure out how easy it would be to effect parallel data transfer.
I wonder if this wire is hot...
Jon Williams
·1+1=10
Just to clarify the terminology, I am used to a long being 2 bytes and 4 bytes being a double.
I get the impresion you might be using long as 4 bytes here.
·1+1=10
