LCD Problems
I am having problems driving a parallel LCD display with the SX-48 Proto board. I am using the code written Al Williams. It works perfectly when using an SX28, but when the same code is loaded into the SX48 second line feature doesn’t work correctly, the message sometimes has random characters in it, and is not located properly. I have attached the code that I am using for the SX48. I could use some help on what I am doing wrong.
If not you can download it from here: http://forums.parallax.com/showthread.php?p=517621
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
"Ability may get you to the top, but it takes character to keep you there."
Jon Williams
PS using indentation in your programs makes it much easier to read for you and us.
·1+1=10
SX/B DOES automatically handle the code pages, but you have to declare your subroutines using the SUB directive.
See the template from the help file.
SX/B has changed quite a bit since Al's book was written.
Bean.
Jon Williams
