best way to control 20 photoresistors
I need to read 20 photoresistors and be able to view·anyone of them at any given time. i assume i would need 20 input pins to be able to do this, i will also have a push button in there so I would need 21 if i assumed correctly. what would be the best stamp module or combination? Im looking for the most simplistic route, with cost, complexity, etc. thanks.
sean
sean
Jon Williams
Merely by way of example, Analog Devices AD7490 is a 16-Channel, 1MSPS, 12-Bit ADC which only requires 4 pins for synchronous serial access (SHIFTIN/SHIFTOUT). Here is the Analog Devices web site:
http://www.analog.com/en/index.html
Bruce Bates
<!--StartFragment -->
