BS2 OEM Kit
Just received my BS2 OEM Kit.
The board is silkscreened R1 and R2 = 4.7K, and R3 = 10K.· The schematic in the package says R1 = 10K and R3 = 4.7K.· Can someone clarify, please.
Sid
Sid
Sid
·· That picture is actually a slightly older revision.· What's missing is the 10K resistor in parallel with the resonator.· That resistor is 10K, the other two are 4.7K.· There are actually more resistors but they are in the two SIP resistor packs (10K).
csavage@parallax.com
As you can see, I had to attach a small wood spacer to the bottom of OEM board so that the soldered side would not touch the pins of the BS2E underneath it.· Now I have two Stamps and two breadboards, all within the size of the BOE.
Sid
