Large Wheels
Any one know where I can get large wheels that fit on the Parallax·Continuous Rotation Servos?
·on····· plane··········································, when catching ducks
"In this house, we obey the laws of thermodynamics!"
http://profiles.yahoo.com/jsmasterking
Post Edited (jsmasterking) : 6/21/2006 12:45:36 PM GMT
Parallax has a nice pair... http://www.parallax.com/detail.asp?product_id=721-00001-721-00002
But, I have doubts that servos will really support the leverage of lateral loads created by larger wheels. It would be better to have the wheels on there own weight bearing axel and then have the servo drive the wheel by a gear, a chain, or a small rubber wheel pushing the larger one.
I like the idea of using the servo horns. If I wanted to make the wheels, what should I use?
Post Edited (jsmasterking) : 6/21/2006 12:45:35 PM GMT
Try white nylon sheeting or aluminum, both soft enough, but aluminum is stronger. then slit a rubber hose to fit the circumferance of
the aluminum hub, and weld ends using super glue for a nice rubber wheel look.
Bob N9LVU
but depending on the power of your servo and the size of the wheel, you might want to use aluminum servo horns for strength.
Just a thought... Tiger
Servos often come with an assortment of servo horns and one of them is usually round. The round one is almost the same diameter as the slight ridge at the center of CDs. The round horns that I have need to be turned down by about 1/16 of an inch to fit snug inside of the ridge. If you work carefully you will be able to make the horn and CD be perfectly concentric without a whole lot of trouble because the ridge will guide the horn into place. Bolt them together after you are happy with the fit.
Now for some traction -
Get some 1/2 inch wide rubber bands from your favorite office supply, the ones that are the 3 1/2 inch size (or a little bigger). They will fit around the circumference of the CD (yes it can be done!) and give some nice traction.
Fortunately, in Taiwan these inner tubes are availble for free in used condition.
If you want, I can send you a hunk.
Alternatively, you can use two CDs with a spacer between to make one wheel.· Then you might be able to locate some large O-ring seals in your local area [noparse][[/noparse]try food containers]
Whats the best way to cut aluminum sheets?
Post Edited (jsmasterking) : 6/21/2006 12:45:28 PM GMT
Also, there are different kinds of aluminum - very soft and more structural.
I suspect cutting circles in larger diameters would best be done by rotating around a center and using a saber saw or other fine toothed blade. Cutting on a lathe would be better.
Sheets can best be cut on metal shears found in Heating and Ventalation shops.
Incidentally, Aluminum's molecular weight is near to exactly 50% of Iron. Still Aluminum is about 5 pounds/cubit foot heavier that concrete.
Mutiple CDs should be strong and lighter. Neoprene glue might work best [noparse][[/noparse]a.k.a. contact cement] Try using the water based version if you have trouble with the solvent melting the CDs.
For anyone who is interested, I am building a two-wheel, auto-balancing, robot based on andromotion from Androbot. If anyone wants the plans for the body, I have some CAD files. I need larger wheels because the parallax wheels are too small and the whole thing tips over when I go at full speed.
Post Edited (jsmasterking) : 6/21/2006 12:44:52 PM GMT
Hold the horn against the CDS, and mark with a fine tip black marker where the holes will be.
Then use a SMALL drill to drill pilot holes, or just melt the holes using a very fine iron...
You should have no problem, and then you keep from mucking up the servo horn...
Bob N9LVU
http://home.earthlink.net/~botronics/index/robots.html
www.bgmicro.com/prodinfo.asp?sid=03975462962962961441711371&prodid=ACS1480&page=1&cri=wheel&stype=3
www.bgmicro.com/prodinfo.asp?sid=03975462962962961441711371&prodid=ACS1481&page=1&cri=wheel&stype=3
csavage@parallax.com
