I2C help
I am trying to communicate with an EEPROM chip (24FC515) using the bs2pe and it is not working.
The code I am using is as follows:
'{$STAMP BS2pe}
'{$PBASIC 2.5}
'{$PORT COM3}
sda PIN 0
current_ptr_b0 VAR Byte
address VAR Word
data_out VAR Byte
addr VAR Word
result VAR Byte
'The main loop
MainLoop:
GOSUB Init
GOSUB write_eeprom
GOSUB read_eeprom
DEBUG "Value read:",HEX result,CR
END
Init:
current_ptr_b0 = $00
data_out = $02
RETURN
write_eeprom:
I2COUT sda, $A0, current_ptr_b0, [noparse][[/noparse]HEX data_out]
DEBUG "writing Addr: ",HEX addr, " Value: ", HEX data_out, CR
PAUSE 2000
RETURN
read_eeprom:
I2CIN sda, $A1 , 0, [noparse][[/noparse]result]
DEBUG "reading Addr: ",HEX addr , " ", "Value: ", HEX result, CR
PAUSE 2000
RETURN
The data that the stamp reads from the chip is always 1. I dont know why!
I am using 4.7k resistors and sda is connected to pin0.
Please help!
'{$STAMP BS2pe}
'{$PBASIC 2.5}
'{$PORT COM3}
sda PIN 0
address VAR Word
data_out VAR Byte
addr VAR Word
result VAR Byte
'The main loop
MainLoop:
GOSUB Init
GOSUB write_eeprom
GOSUB read_eeprom
END
Init:
data_out = $02
RETURN
write_eeprom:
PAUSE 2000
RETURN
read_eeprom:
PAUSE 2000
RETURN
Please help!
It appears from the data sheet that the ADDRESS must be 2 bytes (one WORD) in length. Thus, the ADDRESS in the I2Cxx commands will need to be specified in the "ADDRESS \ LOW ADDRESS" (separated bytes) format as shown in the PBASIC Help file, or the PBASIC Manual. In other words, something like this:
curr_ptr_b0 VAR WORD
I2COUT sda, $A0, curr_ptr_b0.highbyte\curr_ptr_b0.lowbyte, [noparse][[/noparse]HEX data_out]
and
I2CIN sda, $A1 , curr_ptr_b0.highbyte\curr_ptr_b0.lowbyte , [noparse][[/noparse]result]
Bruce Bates
<!--StartFragment -->
Jon Williams
I used the code (with modifications for the 24fc515 chip).
I get a 'fail' output when I do this.
Also: the output that the stamp reads is '1'.
Any suggestions about what I might be doing wrong?
Jon Williams
Do you have the Stamp and EEPROM chip wired as follows:
Stamp Pin Port 0 ==> SDA (EEPROM pin 5)
Stamp Pin Port 1 ==> SCL (EEPROM pin 6)
Vss (EEPROM pin 4) ==> Ground
Vcc (EEPROM pin 8) ==> 2.5-5.5 VDC
WP (EEPROM pin 7) tied to Vss
A2 (EEPROM pin 3) tied to Vcc
Bruce Bates
Could my stamp or eeprom be faulty?
My own guess would be the wiring or something external to the Stamp in some way is causing the problem, but that sounds terribly perjoritive - sorry. BTW - You get the continual 1's due to the required pull-up resistor I suspect.
Bruce Bates
Jon Williams
I rewired everything- again, again and again.
Could the fact that my eeprom chip operates at 1MHz be a problem? Its really fast.... which seems to be a good thing in most cases I thought.
Any ideas about what I am doing wrong?
The input and output pins on the stamp are working. I tested them with an oscilloscope and with leds.
Jon Williams
So, for a write command, I get the following waveform:
1. Start bit. This is ok.
2. Then, the slave id which is 10100000 for a write, this is ok too.
3. Then,..... I need an ack bit. It is a low when the clock is high. BUT- I get a high when the clock is high. So my new eeprom chip is not sending an acknowledge bit. I have attached a waveform to show that.
4. The next byte is a 00000000 for the high byte of the address... so the high that I am seeing could not be the next byte either.
Post Edited (i2c_confused) : 2/25/2006 10:02:20 PM GMT
Conclusion: The i2cin/out does not work. HIGH and LOW commands work! So, I used bit bashing instead.
Here is an example of bit bashing that I modified to use:
http://www.lennard.net.nz/electronics/i2c.html#eepromexample.
Here is the waveform of the output using this code (see attached).
For some reason, my stamp is not working properly.
Approximately how old is this BS-2p? There are I2C differences between the 1.3 (I think that's the version level) firmware and earlier firmware versions. I happen to have one of the eariler versions, which I keep meaning to have updated with the newer firmware.
Bruce Bates
