BS2p40 commands
Can somebody tell me how the OUTL and OUTH commands will work on a BS2p40 IC? On the BS2-24 OUTL references to output 0-7 (low byte) and OUTH to 8-15 (high byte). Since the BS2p40 has 32 in/out pins, how can I command pins 16-31 in this way?
Also I don't get what the difference is between main I/O and aux I/O. Are these not completely interchangeable?
Thanks for your help.
· AUXIO
· DIRL = %11111111··· ' make pins 16 - 23 outputs
· OUTL = %11001100··· ' update pins 16 - 23
Now keep in mind that every I/O operation at this point is directed to the AUXIO group. If you want to switch back to the lower group you can do that with MAINIO.·
Jon Williams
Tracy Allen
www.emesystems.com
csavage@parallax.com
