Boe-Bot Questions
Two quick questions from the boe-bot book..version 2.2:
1)· In the set up instructions for the rev c board of education, the boe bot book says to use the 4
AA battery pack, and set the jumper for the servo header to vin.· If I wanted to use a 9 volt battery instead of the AA battery pack, what should the jumper setting be?·
2)· In the boe-bot book, there is a discussion about computing the time that it takes a for next loop to execute.· Some sample code looks like this:
counter var byte
for counter = 1 to 100
pulsout 12, 650·· '1.7 ms
pulsout 13,850··· '1.3 ms
pause 20··········· '20 ms
next
···"code overhead" 1.6 ms
Total time = 24.6 ms
MY QUESTION:· Now this code is found on pg 83 of boe-bot...I know that 1.6 ms represents the time to execute the for next loop, but on pg 82 a similar loop is shown and it shows only 1.3 ms as the time to execute the loop....I need to know why and how to compute this time to execute the loop, or as the book calls it code overhead.
Rob Morris
counter var byte
next
Rob Morris
But 9-volts is bad, it will burn up the Servo electronics or motor or both.
Now, it also turns out to be helpful, IF you are using 4 alkaline batteries, to run that voltage DIRECTLY to the Servo. That's what setting the jumper to 'Vin' does. The other setting drives the servo with the output of the BOE voltage regulator. Now, the voltage regulator NEVER goes over 5 volts, so that's good if you're using a 9-volt battery. But you do lose some power going through the regulator, which is why the jumper is nice if the Vin voltage is already 6 volts.
So, short answer: IF your Vin voltage is 5.5 to 7 volts, you can set the jumper for Vin. If it's over 7 volts, set the jumper for Vdd.
·· Calculating overhead isn't an exact science per se.· The examples give show the overhead for that given loop, but the actual totals will depend greatly on what else happens within the loop.· You can get an idea of the time required to perform various tasks at the following web page:
http://www.emesystems.com/BS2speed.htm
csavage@parallax.com
