OPT101 PHOTODIODE+OP AMP use as a light meter?
Hello,
I was wondering if anyone knew how to hook up a opt101
(www.alldatasheet.com/datasheet-pdf/pdf/BURR-BROWN/OPT101.html)
to the BS2p ... I am trying to use the opt101 as a light meter and to get basic understanding of the bs2p with analog stuff .. any
info on it ... hardware and software side would be great ... also I want to next hook it up to a AD chip and learn about that aswell
I have been playing around with rctime command but as of yet have not been able to figure out how to hook it up and what to
program to get it to work correctly.
Thank You for your help,
Edgar Cornette
Edgar Cornette
http://forums.parallax.com/showthread.php?p=571402
(at the bottom of the page.)
It is easy to use raw photodiodes in an RCTIME circuit, because they have a current output that can charge a capacitor.
The OP101 gives you access to several nodes in the circuit, and I am thinking it would be possible to set it up as an integrator, and read the integration time via RCTIME. The configuration that comes to mind is to connect a capacitor from the op-amp output back to the inverting input. Also connect the op-amp output to Stamp pin p0 (for example). You need a means to reset the integrator. Connect the OP101 internal 1 meg resistor to Stamp pin p1. Making p1 high will reset the integrater and bring the output to p0 low. Releasing p1 to an input will allow the integration. So the program would look something like this:
INPUT 0
HIGH 1
DO
INPUT 1
RCTIME 0,0,result
HIGH 1
DEBUG DEC result
PAUSE 1000
LOOP
The capacitor would be chosen to give an integration time of something like 10000 microseconds. I have not tried this--just thinking.
Tracy Allen
www.emesystems.com
What I was thinking of was something along the lines of the following schematic:
-- edited original image to show correct (+) and (-) op-amp inputs.
The circuit inside the dashed line is contained within the OPT101 chip (including the photodiode, which looks out through the transparent case.
The capacitor from pin 5 to pin 2 integrates the photocurrent, and produces a rising voltage on the Stamp pin P0.
The 1M resistor that would normally provide feedback is instead tied to a second Stamp pin. Making that pin an input allows the integrator to operate, but bringing it HIGH forces current into the summing Node and resets the integrator.
I already posted the code I think will work. The difference from normal usage of RCTIME is that the reset is done on a different Stamp pin, so there is a little delay before the RCtime command starts. The capacitor has to be large enough, which will depend on the light level. And the extra delay has to be taken into account in the calculation.
I haven't tried this circuit yet, but I do have some OPT101s and might get around to it. Let me know if it works{!}, if you do try it.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 2/22/2006 7:01:32 PM GMT
Thanks for all the info guys... Yes I am going to try that tonight Tracy if I get a chance... I went ahead and ordered some ADC's from digikey just in case i cant get this opt101 to work wel without one... my main goal with this was to be able to tell if a the lights in the room are on or off and to also use one to detect sunrise and sunset and also to make a light meter that will let me check my 1,000 watt high pressure sodium light to see how it puts out with the current reflector and maybe to tel when to replace the bulb as its output lowers with time and it gets to a point that its not putting out near what it was new. well i can think of several more ideas to use this for aswell... if i can just get a handle on how to get what i need out of it ... just take me some time to get up to speed on some of the newer stuff ... i went to school for electronics .. and when i was done .. there was no jobs i wanted to do .. i loved computers (vic-20, commodore 64 , ti994a, my first apple was built by hand). but at the time there was no computer courses anywhere .. so i took the basic building blocks of them ... electronics ... then after school i learned on my own and then when they had courses i got my computer and network engineering degrees.. so now i am back learning some of the stuff i missed in the electronics side [noparse];)[/noparse] so forgive me if i am alittle slow sometimes to catch up.
Thank You,
Ed
I also extended the program with an inner DO loop, because indoor light levels extend over several orders of magnitude. Multiple RCTIME commands in the loop detect longer intervals in dim light.
wt0 VAR Word wt1 VAR Word ' for extended time acquisition INPUT 0 HIGH 1 DO PAUSE 64 ' pause to reset integrator wt1=-1 DO wt1 = wt1+1 ' will show how many RCTIME timeouts occurred INPUT 1 RCTIME 0,0,wt0 LOOP UNTIL wt0 ' RTTIME times out with wt0=0, repeat loop until it is not 0 HIGH 1 ' reset integrator DEBUG DEC wt1,".",DEC5 wt0,CR PAUSE 1000 LOOPEdit: added optional R=1kohm for faster reset in bright light, and option of larger capacitor, also for bright light.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 3/9/2006 7:12:34 PM GMT
In average indoor room light, the 0.01uf capacitor and the 1Mohm resistor suffice.
Tracy Allen
www.emesystems.com
I am a Ph.d student and part of my project (underwater optical wireless communication) is to design an optical wireless system.
I am using OPT101 in a reciver circuit based on FSK modulation. I got a problem with the effect of the strong ambient light. Even, I put an optical filter on the OPT101 but the problem still which is the strong ambient light affect the circuit from receiving the correct data. However, with the room light the circuit is working fine and reciving the data correctly but with the strong ambient light the circuit stop reciving data and sometimes just reciving rubbish data.
I am using XR2206 as FSK modulator at the transmitter and XR-2211 as FSK demodulator at the receiver. Also, I am using the green light at 520nm.
Any suugesstions and feedback will be appreciated.
Thanks all
